[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Reply for Smilez:-)
You need to unpack the archive "OpenELEC-CodeSnake-Meson8-K200-devel-320a148.zip" with Winrar or Winzip, and then you put the 3 files "factory_update_param.aml + OpenELEC-CodeSnake-Meson8-K200-update.zip + recovery.img" onto a SD-card and insert it into the M8 box, and enter recovery using a toothpick* The installation should start automatically.
- Unplug the power to the box.
- Using a toothpick or something similar, insert it into the back of the A/V port until you hear a slight click sound. (This is the hidden button in the A/V port and you should be able to feel the button depress)
- Holding the button down in the A/V port, you will plug the box back into the power.
- You should now be in recovery
Originally posted by smilez View PostBut im not getting stuck at the matricom logo. I run the recovery then I run 1.1.6 which installed fine. It's installing openelec I have a problem with. Codesnake said look for ZIP file. When Downlaod the 4.2.1 file it decompress itself when it finish downlaoding. The whole the time I went into the folder an compress the four files that was in the folder. When Trynna to install from ext it would say archive .zip and it wouldn't work. But then I figured I was suppose compress the folder without going in it. It rename it as what I downloaded as but it still wouldn't install. When Trynna install from ext It say recognizing file look like it's gonna install robot is up the it will abort install. Idk wish there is a vid on this to see what I'm doing wrong. I'm not tech savvy at all but I do appreciate u guys Trynna help me.
Looks like I'm getting 2.8mbps on wifi on a 50mb connection and only slightly better with ethernet? OpenELEC:~ # time wget -O /dev/zero speedtest.tweak.nl/100mb.bin
Connecting to speedtest.tweak.nl (217.19.16.132:80)
zero 100% |*******************************| 100M 0:00:00 ETA
real 0m 35.60s
user 0m 0.13s
sys 0m 1.39s
What's up with that.
Originally posted by codesnake View PostRecovery was updated by OpenELEC. So we should have the same version.
Only strange thing is if i revert back to android and change the resolution to 1080p then go back to openelec it starts up 1080p (before 720p) but as soon as the openelec logo appears it reverts back to 720p
Originally posted by codesnake View PostIf someone wants to help the development and have such a failing M8 box, you can donate it to me, and I'll try to fix the issue. Otherwise I cannot reproduce the issue and unlikely will be able to fix it.
I have exactly the same problem... I hate it
Love codesnake openelec but hate that I have no cec and 1080...
Originally posted by mannyp View PostTell me where to send it to you codesnake I'll be more than happy to do it.
Originally posted by codesnake View Post@nukeybrown was faster
There are currently 2042 users online. 0 members and 2042 guests.
