[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
    Welcome,
    I have Gbox MX2 on Amlogic AML8726-MX.
    How can I return from openelec to android firmware?
    Greetings
      Originally posted by androidgadget11 View Post
      Welcome,
      Greetings
      Flash whichever firmware you want from here.
      The new Matricom Wiki page is coming soon!
        how do i backup my addons and stuff?
            You can also use OpenELEC's backup.
              wherrs that
                wherrs that
                It's in the OpenELEC Configuration. It will make a back up of your system that you have OpenELEC running on. It will be a .tar file and be easily accessed through samba share from your home computer. And you can even store the .tar file on a flash drive to use it to restore a different box through file manager. If you wanted to go that option.
                  how do i set up samba plz?
                    This is also how you log into your box to get to the backup folder.
                      Probably a stupid question, but can you restore a Gotham backup to a helix install?
                        I tried Gotham OE backup on helix, and it did not work
                          Thanks. Thankfully the update from Gotham to Helix worked without issue so the backup is not required.
                            Ahhh thanks for that idea
                              Any way to get an android box to boot OE from a stick?
                              The question says it:
                              Is there Any way to get an android box to boot OE from a USB stick?
                                I'm not sure whether this is specific to my M8 (or it's 2A power supply) or if others are suffering from the same problem, but I am suffering from freezes when browsing the menu. For example I have just had to pull the plug on my box after browsing the TV Shows library.
                                I have also experienced the TV Show I am watching seemingly pause but only showing a black screen. However the remote stays active and if I stop the show I can resume it again from where it left off. I'll try to provide a log for these issues.
