[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by lavaman View PostI apologize if this has been answered but will this Rom work with the m8n with the square remote.
I have an m8n round remote works perfectly.. If remote doesn't work there is a post with round and square remote file that you can flash too make the remotes work..
Originally posted by codesnake View PostI don't know for sure. Maybe bad HDMI cable, or some incompatibility between HDMI driver and the TV.
Originally posted by nukeybrown View PostHi codenake I'm also getting cannot change resolution and nil edid when ssh into device, m8 running latest gotham build on 2 samsung TVs under 12 month old, tried different HDMI leads and still the same so don't think its hdmi related, not 100% but sure I could change it on earlier builds of openelec.
Originally posted by nighthawk1975 View Posthello codesnake
I have a mxIII..2gb. Can i use this one on my box? It's hard to find out if the M8 and MXIII can use the same firmware. And will cec work on my box?
Thanx for your great work.
Originally posted by noosk View Post@nighthawk1975, Did you have any luck installing this on your 2gb MXIII? If so, how did you install it?
I updated to 4.95.2 to give it a go. All settings were carried over and the experience was snappy and fluid. I have found numerous bugs though -
-No WiFi at all
-The OE Config is blank for the most part (see attached)
-On screen keyboard is blank and are not able to type even with a usb keyboard (see attached)
Originally posted by noosk View PostNo need, I installed the CEC Gotham version on my MXIII 2g using the toothpick method and it works really well.
-No WiFi at all
[ATTACH=CONFIG]8896[/ATTACH][ATTACH=CONFIG]8897[/ATTACH][ATTACH=CONFIG]8898[/ATTACH]
Originally posted by codesnake View PostI can confirm that there's a problem with Wi-Fi in OpenELEC 5.0 Beta2 for M8. But the other two issues is most likely caused by the fact that you use a skin that is not yet compatible with Kodi.
How can you test your internet speed on this build? I have an M8 and seem to be getting a lot of buffering issues that I didnt get with Stanes MX linux?
Tried this but can't make head nor tale of it
OpenELEC:~ # time wget -O /dev/zero speedtest.tweak.nl/100mb.bin
Connecting to speedtest.tweak.nl (217.19.16.132:80)
zero 100% |*******************************| 100M 0:00:00 ETA
real 0m 35.60s
user 0m 0.13s
sys 0m 1.39s
There are currently 3374 users online. 4 members and 3370 guests.
