[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View Post
Originally posted by codesnake View PostWhat box do you have?
Thanks for your response, but I have worked it out. Just extracted the .zip file to an sd card and booted while holding the reset button for 3 seconds.
The install happened automatically.
I believe that previously I had extracted the upgrade .zip instead.
292e?
Hi there
Still enjoying your great release which is still working perfectly.
I am just wondering if there's any hope for my USB DVB dongle...
The driver for my USB DVB stick (PCTV Triplestick 292e) is apparently part of the 3.17 Kernel but not 3.10. Does this mean that my DVB stick is useless for the time being or is there anything I can do about it? (I have no clue about Linux)
Thanks for your help and all your hard work
An alternative maybe?
like you, i purchased the PCTV 292e dongle, and was planning on running it in my MX2 directly, which i'd like to say, has pretty much come alive once i got rid of the Android firmware (Thank You Codesnake!)
Anyway, i found a really nice way which works perfectly for me.
It seems that DVBLink is a perfect match with this tuner; i just downloaded the latest BDA drivers from the PCTV website and went and installed DVBlink components on a (any) Windows backend. Plugged the tuner in; let it scan and installed the DVBLink client in XBMC. Works really great and all recordings are on my laptop to watch when i am away from home ;-) You could also run the backend on a NAS for example.
Only one ' downside' as it's not free, but you can activate a 20 day trial.
OpenELEC for Amlogic 5.0 Beta2
OpenELEC for Amlogic 5.0 Beta2 with Kodi 14.0 Helix Beta2 is available now:
Download links for M8:
- for updating the exisiting installations: https://github.com/codesnake/OpenELE...arm-4.95.2.tar
- for new installations from recovery: https://github.com/codesnake/OpenELE...arm-4.95.2.zip
Download links for MX2/G18:
Originally posted by foz View Posthi codesnake
will the update over write userdata file? do we need to back our settings up first?
and how do we update with .tar sorry if been asked before
any release notes codesnake whats been updated?
foz
Updating using an update TAR file will preserve your settings, addons etc.
Originally posted by codesnake View PostOpenELEC for Amlogic 5.0 Beta2 with Kodi 14.0 Helix Beta2 is available now:
Used Update v.2 from xda
There are currently 2988 users online. 0 members and 2988 guests.
