[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View PostI think that except of different housing and the remote, MXIII 2 GB version and M8 are almost identical.
You can also consider the MXQ box, which is based on S805 chip. It has less powerful GPU, but is cheaper than S802-based boxes and features support for HEVC hardware decoding.
installed OpenELEC-CodeSnake-Meson8-K200-devel-320a148 on MXIII
Hello codesnake,
I installed this firmware on my mxIII box..
Quick install and cec works.. But it freezes real quick.. (HDMI)
And i need to reboot. maybe hdmi with cec problem.
- cec works
- wifi works
- very fast
So i decided to get back to android. I hope that there will be a stable firmware for MXIII soon.
Or do you have a solution that i could try?
Installed the full version on my H8M8 box. (I find it best to do a clean wipe with any update).
HDMI-CEC is working beautifully, and the build is running well. Even better than being able to use my TV remote, I can now switch the box and TV on and off together with a single button.
Thank you.
Originally posted by Zahir View PostInstalled the full version on my H8M8 box. (I find it best to do a clean wipe with any update).
Thank you.good work CS
Bugs are Sons of Glitches!
JustMe
Originally posted by polys View Post
There are currently 2218 users online. 3 members and 2215 guests.
