[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by Tyler Durden View Post
Originally posted by Jarv1ss View PostIs it normal for the first splash screen (the chip) to be displayed for so long, 70 seconds in my case. The mx2 version has a total boot up time of less than 30secs.
Codesnake, which do you prefer to use in terms or performance and stability? Mx2 or m8?
I prefer to use M8.
Originally posted by codesnake View PostNo, that's not normail if the first splash is displayed for 70 seconds. Boot time of the M8 and MX2 should be almost identical.
I prefer to use M8.
Message at top left saying "starting debugging shell... Type exit to quit### can't access tty; job control turned off"
additional info. I flashed the OE on top of stanes Linux. I know you said it doesn't matter which fw you flash on top of but could that's be an issue?
Originally posted by Jarv1ss View PostTurned off and back on. Now won't boot last the openelec splash screen. Stuck. ��
Originally posted by De Bouwer View PostWhatever i try, i cannot select 1920x1080 on my m8.
My samsung tv supports it but it only shows 720?
When i had my pi it was 1920x1080.
I tryed diferent hdmi cables but nothing helps.
Any cleu what i can do to fix it?
I'm on codesnake's newest realese (kodi beta)
De Bouwer
Re: [ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by pigbait View PostStupid question but have you tried a different HDMI cord/port
If I plug-in my pi it is 1080 and I can use cec.
But when I plug-in my m8 it all doesn't work.
I dont know what to do anymore.... wish i could go back to droid, atleast cec and 1080p was working.Last edited by De Bouwer; 13 November 2014, 20:05.
There are currently 4173 users online. 3 members and 4170 guests.
