[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Guest
Originally posted by noosk View PostS806 is the model number of the device, not the chip. It's an s812 chip which is amlogic
Guest
@codesnake or someone
Can we please have a new test build for m8 with https://github.com/surkovalex/OpenEL...0b73af873be757
I hope that solves 23,976 issue, right ?
Originally posted by wackidth View PostDuhhhhh as if I don't know that..... I know a CS806 has aS812..don't need to teach me.... Foz asked that question....
I did not ask what soc the box had I just asked what the box was
"what is the Amlogic 806 listed here? is it for the CX-S806 box?"
I can only find details on cx-s806 is this what you would call S806 box?
sorry for confusion
but thanks for your help
foz
Originally posted by foz View Post
http://xbmc.ru/forum/showthread.php?t=4587
Originally posted by MikeD View PostIt's definitely for CX-S806 box. You can have a look at here which are the supported models from amlinux.ru:
Originally posted by techloomp View PostIs build for MXQ box dead ? I'm using Android ROM, but OpenELEC would be x100 better.
Using the MXIII 1gb ROM on a 1gb s802 square M8
Does anybody know if the ROM zip from xbmc.ru named:will work with the square M8 1gb model?? I recently installed the S82 on an M8 and it worked averagely, with a few small glitches. The 1gb M8 I have is useless so I am trying to upgrade it and this is the only similar 1gb ROM I can find. Any help?? Has anybody tried this? I am looking for a ROM for a 1gb s802 M8 square box... Does anybody know of one??MXIII 1Gb rtl8188
Re: [ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by NIPSZX View PostDoes anybody know if the ROM zip from xbmc.ru named:will work with the square M8 1gb model?? I recently installed the S82 on an M8 and it worked averagely, with a few small glitches. The 1gb M8 I have is useless so I am trying to upgrade it and this is the only similar 1gb ROM I can find. Any help?? Has anybody tried this? I am looking for a ROM for a 1gb s802 M8 square box... Does anybody know of one??MXIII 1Gb rtl8188
There are currently 5185 users online. 1 members and 5184 guests.
