[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
I try to compile openelec source. script download kmod and compile it. later have error. codesnake pls How I can fix
make[3]: Nothing to be done for 'install-exec-am'.
make[3]: Nothing to be done for 'install-data-am'.
make[1]: Leaving directory '/home/new/Downloads/openelec/build.OpenELEC-Amlogic.M8.arm-devel/kmod-19/.x86_64-linux-gnu'
fatal: Not a git repository (or any parent up to mount point /home)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Makefile:9: recipe for target 'release' failed
make: *** [release] Error 128
root@new-VirtualBox:/home/new/Downloads/openelec
Originally posted by taki View PostI try to compile openelec source. script download kmod and compile it. later have error. codesnake pls How I can fix
av output
Hi, everyone, does the av output work for somebody, or i need to compile kernel with other parameters for make it work. Didn't have sound or video on av. Hdmi is fine. Wanted to know if it was possible to output sound to av and sametime passtrough spdif? Maybe my cable isn't correct. buy a camera cable 3.5mm to 3 rca. Tried every combinaison for video and audio.
thanks
Originally posted by boipie01 View PostHi, everyone, does the av output work for somebody, or i need to compile kernel with other parameters for make it work. Didn't have sound or video on av. Hdmi is fine. Wanted to know if it was possible to output sound to av and sametime passtrough spdif? Maybe my cable isn't correct. buy a camera cable 3.5mm to 3 rca. Tried every combinaison for video and audio.
thanks
Originally posted by codesnake View PostDid you download a tarball or cloned the Git repository?
PROJECT=Amlogic ARCH=arm DEVICE=M8 make -j4
make script download and compile but only kmod source donwload and compiled after this error
Originally posted by taki View PostI didnt use git clone your source. I download your source zip format. later unzip. after
Code:git clone https://github.com/codesnake/OpenELEC.tv cd OpenELEC.tv PROJECT=Amlogic ARCH=arm DEVICE=M8 make
MX2 (G18REF)
Anybody have any idea's, have a MX2 box, brand new. When I rebooted the system it wont boot at all. I get nothing on the screen.
The light on the front will not change from red. Doesn't look like it is coming on at all, any idea's?Last edited by bignelly79; 11 January 2015, 19:04.
Re: [ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Big thanks codesnake, got your rc3 on a m8n and it's great.
Although , I appear to be having a problem with audio on some live streams.
For streams with audio AAC, 32000hz I do not get any sound.
I have tried the same streams on a couple of other devices (rpi running openelec 5.0 and windows running kodi 14) and they work fine.
Any help is appreciated.
Regards, madmaxamus
There are currently 3920 users online. 1 members and 3919 guests.
