Speed is dropping from 99mb to 40mb. Tested on laptop and M8 with same cable. Seem to be losing DL speed on Pulsar as well if related im not sure.
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
m8 not full 1920x1080
hi codesnake,
thanks for the M8 openelec but there is one problem i can not put the size to 1920x1080??
i read that the problem is my tv? or hdmi cable?
but my other box MX2 can display the size 1920x1080
where i can find the original software for the M8 android?
thanks
pinnoes
Originally posted by kszaq View PostCodesnake's builds don't have support for HEVC hardware decoding. You should try using builds from xbmc.ru (links earlier in this thread) - these are based on Codesnake's code with HEVC support and some other minor additions.
I have used recovery method to install minix x8 beta firmware before and I think I need to use the same way?
They have the recovery.img file and a factory_update_param.aml and a OpenELEC-Amlogic.S82.arm-devel-20150113183017-r20272-g0481f0c-update.zip
Any help would be great
Originally posted by dave85 View PostHow do I go about installing builds from xbmc.ru?
Originally posted by WeK05 View PostYep, that will work. You can also put the three files on an SD card and boot into recovery by pressing the reset button during power up. If you are installing this on a Minix, please report whether it works or not. When I tried this firmware, I ended up with a blank screen. codesnake's build does work on Minix X8-H.
Originally posted by Brambo65 View PostI have the same question, where can i find the original software for the M8 android.
I have a blank screen for now, how can i back to the original android ????
thanks
i use this android software and is works very well and gives full hd 1920x1080
here you can find the url http://www.theaterinabox.tv/download use the Armada Mach 8 ANDROID - Code Red Launcher - November 17, 2014 Firmware
let me know how you like this firmware
thanks
pinnoes
I have a square s802 M8. I recently tried several different OpenELEC zips, but most of the ones that did install (I had several NO FOOTER ERRORs), did not have any access to wireless networks under OpenELEC settings. I finally came across a Russian zip on xbmc.ru that installed and it is the latest developer zip found at: OpenELEC-Amlogic.S82.arm-devel-20150113183017-r20272-g0481f0c.zip. After zipping it to the s802, I realized it is for the S82. It still worked but it seems to have some bugginess. Getting stuck on opening stream window and working spinning wheel getting stuck too often. I am used to Stane's MX Linux and got spoiled with speed. Please help, I need a network working .zip with audio/video synced properly and speed. Any suggestions on a more suitable ROM zip? All of codesnake's ROMs do not have wireless. Is there a way to have ethernet hooked up after installing codesnake's zip and then get wireless by downloading a network setting addon or enabling an OpenELEC setting feature??
thanks
pinnoes
Thanks pinnoes, i will try it next week,this is the original firmware for the m8?
bedankt en ik laat weten of en hoe het werkt.....
just reading through this thread and looking at
http://amlinux.ru/image/5.0.0/
what is the Amlogic 806 listed here? is it for the CX-S806 box?
foz
Guest
That's no Amlogic chip. It's the CS806 box.
You can use S82 in a square M8. IR remote does not function.
Guest
Originally posted by noosk View PostThat's incorrect. It's for the cs-806 which is an amlogic s812 soc.
So why you are saying incorrect?
There are currently 2597 users online. 1 members and 2596 guests.
