OpenELEC for Amlogic 5.0 RC3 is available now. See the first post in this topic for more details.
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View PostOpenELEC for Amlogic 5.0 RC3 is available now. See the first post in this topic for more details.
Let's see if changing live-tv views (full-to-window) works again in rc3!
Guest
Guest
Tried to update my stable 4.2.1 installation to RC3 using the SMB and toothpick method.
It seems that the PVR side of KODI is a step down in my particular setup (using DVBlink Backend with the new PVR addon included).
Issue: switching live channels results in a black screen. Restart seems to (temp-) fix it.
Issue of the earlier RC builds is gone, though (resizing results in 3/4 black screen with small tv display portion).
\EDIT
After playing around with the different XBMC/KODI + DVBLink forked versions, i had to revert back to 4.2.1 Gotham + DVBLink PVR Addon 1.9.1.2 from oberon to have to ultimate most fluent setup.
It seems that Team XBMC is doing a lot to improve their PVR options, i really would like to use it when it all settles :-) For me, their version of the DVBlink addon just isn't there yet. Too bad the DVBLogic versio is not (yet) compatible with Helix.
As far as this Openelec test version goes apart from the PVR issues it's a real improvement over the current stable!
Thanks goes out to Codesnake...again ;-)Last edited by IMFan; 06 January 2015, 19:51.
Originally posted by warlock09 View PostHello @ codesnake it might be asked before but i will try to ask again..are you working on an openelec build for this box..thanks..
I have this box T8 single band wifi older one..black color thanks.., hold pin in for a while b4 a quick red screen then it will load OE, release once you see the robot
There are currently 2354 users online. 0 members and 2354 guests.
