reboot recovery
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by phil View Posthi have type reboot recovery but go,s back to boot screen at the top of screen it say.s .error in mount-storage could not mount/dev/data.starting debugging shell can,t access tty:job control turned off type exit to quit but if i do just reboot,sCode:reboot recovery
Originally posted by duke333 View PostHi all,
Can any one help with my problem from last week?
It installs fine i can set everything up and all the add ons work fine but once i turn it off and back on i get the same screen as shown in dukes post. Any help would be greatly appreciated.
Cheers
Originally posted by phil View Posthi got in recovery but when i try to load it say,s e:error in /tmp/sideload/package.zip(status 7) installation aborted on any image
I've used the TV110 image
It is all working... except those 2 factors
1 - 10/100 only on network not 1000
2 - Sound is hit and miss. Pass through is causing issues on some. The problem is occurring when playing back a high def file with dts/ac3 sound.
I don't know if this is meant for a 802....805...or whatever. The fact is that it is performing brilliantly (much snappier than android) - along with the fact I can set the resolution to adjust to match the file played.
Any ideas?
TV110 with Amlogic S805 SoC - coming soon !!
Any ideas?
Originally posted by handroid View PostAfter installing OpenELEC on an MX2 the setup wizard hangs on the Network screen. The screen stays blank and the Next button is inactive.
Who knows how to solve this?
i personally would start over, re download the file and flash it flash it again.
if using auto flash files I would first > recovery and factory reset and then clean cache then try auto flash it
hope this helps
Originally posted by foz View PostSorry I don't have mx box but are you sure you installed the correct file for your box?
hope this helps
There are currently 4082 users online. 1 members and 4081 guests.
