[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Is there any way or hope for dual boot with Android?
I'd love to use my USB DVB-S2 tuner with this box in OpenElec but I would also like to play some games from time to time.
What would you suggest is the best setup for these purposes?
It could be possible as Wetek version runs from an sd card.
That's true, but I figured there might be limitations regarding the chip, since it sports only an AML8726-MX (with 1 gig of RAM and a Mali 400) which has a rather weak chest when it comes to gaming if I am not mistaken. But I have to admit that I do not know anything about stuff like bootloaders etc. in this field of devices, yet.
Are there any dual boot alternatives with the hardware specs of the M8 or is there an Android app that allows communication with a USB DVB-S2 tuner so I can use this for LiveTV and do my usual media center stuff in the XBMC app?
Have MXQ S85 Amlogic S805, with bluetooth...if you need a some testing done give me a shout, happy to use box as test box as I just bought to run OpenELEC
Hi Codesnake i have the CX-S806 which in general i am quite happy with. When looking online i came across a Russian forum that has a version of openelec 4.97.2 for my box. I am a bit worried about updating or trying it.
Its a zip file which i have uploaded to my dropbox
Wonder if it would be possible to have a look over and see if it looks OK? I think there is a few versions of this box mines is the sunnytech one with 2gb & BT.
Update
Tried both files listed on the site and neither would install for me. Began installing and then said that the footer was wrong
