[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
    Originally posted by Tyler Durden View Post
    When I upgade to Helix my box freezes every time I scroll through either my TV Shows or Movies. The only way to get out of it is to unplug the box and plug it back in.
    Here is the debug log:
    I have tried changing to Confulence skin but the problem remains.
    Here's another debug log from when using Confluence Skin.
    Just noticed the CPU is only being shown as 2 cores in Helix, when it was correctly showing 4 when in Gotham.
    Just switched back to Gotham and the freezing problem has gone.
    OK. I am using the Gotham build on my M8 and I have a problem.
    This morning I started watching the last episode of Peaky Blinders (which is awesome by the way) and at 29mins in playback stopped. The picture went black and the sound stopped. After a minute or so it returned to the menu system and I could start the file playing again, in fact I was able to resume from the point at which it stopped.
    Can anyone here explain why this happened? I have uploaded the standard XBMC.log file here. Debug log not available at present.
    Thanks in advance for any help.
    Can anyone shed any light on any of these issues?
      error
      hi , i try to install the openelec linux version 4.2.1 to my mx 2 box and always i have this error.....and stuck there.
      i install it over 1.1.6 as codesnake said....
      any advise or help pls.....TIA
        M8 S812
        Hello Codesnake, great work! Is it yet possible to install on M8N S812? Or currently only de M8 K200?
          Yes, it is possible. But the remote will not work properly by default.
            M8N S812
            @CodeSnake. NICE, your the man!! Any solution for fixing the default remote. If no solution guess a remote on phone will work of will this also give problems?
            No remote issues with K200 firmware by the way?
            Last edited by PatrickWoonings; 01 December 2014, 14:10. Reason: additonal question
              Just so people know, this build works on MX3 2gb boxes, only thing that isn't working is remote... thanks again codesnake
                If I install it on M8S it will work but with no remote control support?
                  Are my issues not important? Or is this not the right forum for trouble shooting?
                    You should undesrtand that Kodi is beta software, so you should expect to have some issues.
                      Don't install the firmware for M8 to M8S. It is incompatible!!!
                        Re: [ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
                        Apart from the freezing menu which makes Kodi Helix completely unusable, these issues are on XBMC Gotham.
                          But it seems these issues have only you. I cannot reproduce them.
                            Although these issues might be very important to you, they cannot be reproduced. Furthermore, what keeps me from replying is the fact that you keep mentioning them (even quoting yourself and all your posts, cluttering things up without reason).
                              hi all
                              today received CMX AML8726-MX
                              not working just red light ??
                              can any one tell me how to work the box ??
                              I Try open recovery mode i cannot open recvery mode
                              still red light
                              GEEKBUYING
                                Originally posted by MbTsM View Post
                                hi all
                                still red light
                                GEEKBUYING
                                Did you try the box before flashing?
