[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by pajopasa View Post
Found what went wrong, used WinSCP and I don't know why.
Guess it was to early and not enough coffee or maybe to much.
I then used explorer like I always have done and all went well....
Cheers
Originally posted by codesnake View PostI updated my M8 using the same TAR without problems.
Originally posted by bobones View Post
Hello codesnake, having major audio issues, with m8 ROM on t8 box, works fine for a while then no audio at all. When I attempt to make changes to the SYSTEM, AUDIO settings as soon as I go into them I am unable to navigate and the AUDIO DEVICE is grayed out and blank. Any advice on why it may be happening and a possible solution. Same happens in confluence skin as in others.
Thanks, Gabs
Originally posted by codesnake View PostOpenELEC 5.0 RC1 for Amlogic-based devices is available now. See the first post in this topic for more details.
Let me introduce a new device I have build for - WeTek Play (http://wetek.com). It is a TV box based on dual core AML-8726MX SoC. It supports dual boot out-of-the-box - you can boot pre-installed Android from NAND, or OpenELEC from an SD-card.
WeTek Play could be equipped with internal DVB-T/DVB-C tuner or dual DVB-S2 tuner, and you can easily use it in conjunction with tvhedend to watch Live TV in Kodi/XBMC.
Originally posted by BTopbas View PostWOW! I am exiciting for this box. But i little search on internet i nothing see device price and seller(worldwide). Where can i buy?
Just received my m8 testing the new OpenELEC 5.0 RC1
I find couple of issues first the remote a bit sensitive press once and sometimes scroll twice through the menus does someone else have this issue ?
Also not showing the Bluetooth adapters is not a big issue but would be nice use my iPazzPort KP-810-10BTT
Many Thanks codesnake for all your hard work.
Originally posted by Xblaster View PostJust received my m8 testing the new OpenELEC 5.0 RC1
Originally posted by codesnake View PostIt seems the steps are correct.
Now on your Github I see there is a newer version (Rc1 of Openelec 5). Is it advised to flash that version and if so will it remove my installed addons and repos? And how whould I flash a newer version (taking into account that I don't seem to have a resetbutton).
Originally posted by Skroif View PostThanks a lot Codesnake! Flashing went perfectly although I used different steps then I originally thought I had to use because I couldn't find a resetbutton and therefor couldn't get into Recovery. Somewhere in the Android invironment you can see the settings of the box and there you can look for updates. I there choose the zip update file and the M8 was flashed with the Openelec which works perfectly!
If you do want to get back to recovery, you can issue the command 'reboot recovery' from a SSH session.
There are currently 2072 users online. 0 members and 2072 guests.
