Any maps which need adding/changing can be done within the xbmc keymaps. A lot easier than trying to define a definite linux remote.conf
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
New build for M8
Here's the promised new build for M8 box.
Updates in this build:- Fixed an issue when you cannot install any addons from OpenELEC official and unofficial repositories. Now you can install tvheadend, vdr, etc.
- Fixed SD-card not mounting issue
- Added support for Realtek 8188EU Wi-Fi module that seems to be used in some M8 models.
- Loads remote.conf from /storage/.config if it exists, otherwise loads standard /etc/remote.conf
Download links:- for updating the exisiting installations: https://googledrive.com/host/0B4FNwq...7b3-update.tar
- for new installations from recovery: https://googledrive.com/host/0B4FNwq...el-bb377b3.zip
Everything working perfectly on my M8N except the remote (as expected). Some of the keys are wrongly mapped (e.g. Volume, context menu etc).
I copied the original remote.conf found in the stock rom to /storage/.config then rebooted but that messed the remote mappings even more. What is the best way for remapping the keys?
This is the remote:
For example, the Menu (context menu) button is swapped with the VOL-
What do I need to change in the following remote.conf (taken from /etc)?
Code:# ZAP-A10 NEC remotefactory_code = 0xfe010001 work_mode = 0 repeat_enable = 1 release_delay = 121 debug_enable = 1 reg_control = 0xfbe40 key_begin 0x4e 2 ;NUM_1 0x0d 3 ;NUM_2 0x0c 4 ;NUM_3 0x4a 5 ;NUM_4 0x09 6 ;NUM_5 0x08 7 ;NUM_6 0x46 8 ;NUM_7 0x05 9 ;NUM_8 0x04 10 ;NUM_9 0x01 11 ;NUM_0 0x42 111 ;DEL 0x51 105 ;LEFT 0x16 103 ;UP 0x50 106 ;RIGHT 0x1a 108 ;DOWN 0x13 28 ;OK 0x10 46 ;MENU 0x41 66 ;MUTE 0x11 78 ;VOL+ 0x4c 74 ;VOL- 0x18 1 ;HOME 0x19 14 ;EXIT 0x40 116 ;POWER key_end
Originally posted by lowsum View PostHow are we supposed to update an existing install with the .tar file? The recovery doesn't seems to recognized .tar file ... and inside the .tar there is a system and kernel file?
There are currently 4100 users online. 0 members and 4100 guests.
