[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by jeep52 View PostOpenelec-codesnake-meson8-k200-devel-320a148
The file name should OpenELEC-CodeSnake-Meson8-K200-4.95.1.zip
Hi code snake.
Link works....Hi codesnake I am wondering if you can help. I have the unltimate XBMC package and I want to replace the .xbmc pakage on your openelec xbc How do I copy the .xbmc to the existing xbmc on your file. I am new ay Linux . AS stated before your firmware is awesome but I is thre an easy way to copy the contenets of my .xmc folder into the contents of the .xbmc folder in openelc.
Originally posted by Bogart7777 View PostLink works....Hi codesnake I am wondering if you can help. I have the unltimate XBMC package and I want to replace the .xbmc pakage on your openelec xbc How do I copy the .xbmc to the existing xbmc on your file. I am new ay Linux . AS stated before your firmware is awesome but I is thre an easy way to copy the contenets of my .xmc folder into the contents of the .xbmc folder in openelc.
Originally posted by brummy13 View Postcant seem to get the update to update. i have to skip this one. will there be a new update?
Originally posted by codesnake View PostOpenELEC for Amlogic 5.0 Beta1 with Kodi 14.0 Helix Beta1 is available now:
Download links for M8:
- for updating the exisiting installations: https://github.com/codesnake/OpenELE...5.1-update.tar
- for new installations from recovery: https://github.com/codesnake/OpenELE...200-4.95.1.zip
Can we just copy the 4 files from the TARGET file into the .update OE file and reboot to force the update? I could do this on OE builds for the Pi so I assume the same would apply to the M8?
Answered my own question!
Yes, by pasting the 4 files from the target folder into the update folder and then rebooting the M8, it forces the auto update and in less than 3 minutes I'm now running Kodi 14.0-BETA1
Also to confirm that HDMI-CEC works out of the box so to speak, with no configuration needed to enable it.
Awseome work and thanks, CS
There are currently 4076 users online. 2 members and 4074 guests.
