[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by tomjohnbob22 View PostHi i need help. Everytime i try flashing the openelec on my M8 box, it will get stuck during the process. It will get stuck at the same spot everytime. Is it possible that my box is bricked? Has anyone come across this? Can anyone help me? Thanks in advance
Where exactly are you getting stuck at?
Originally posted by al8782 View PostMy Logitech K400 is working on my box. I have G Box Quad Core
Thanks Mike
Originally posted by Michaelpr001 View Post
What version of opnelec do you run? I have a um8 box and also a gbox q and want to add openelec to both . I assume you use the codesnake m8 that this forum is based around ...... M8/2gb
Thanks Mike
I have ported OpenElec to the Beelink S82 Plus.
It's still a pre-release but you can try it and provide feedback:
mirrorupload.net ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf mirrorupload.net alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Some buttons of the remote do not work: OK, mouse and maybe some other.
Wifi, wired network, accelerated video, audio, etc do work.
Please report anything you find so that I can fix it.
Originally posted by ute View PostHi guys
have just put OE on my MX2 but it is 5.0.3 would like to update but not sure which version to grab or even if there is any update to Isengard yet .
http://www.mediafire.com/download/g9t59 ... 5.95.2.tar
http://www.mediafire.com/download/ww4bl ... 5.95.2.zip
Originally posted by codesnake View PostSquare
Thanks for the better solution.
I have used the M8 version for my Zoomtak T8 - v1 and it is using the audio pass trough sample rates now, studio quality out of my box
The standard infra red interface isn't working so even with a tool like Key Locker the remote dont works.
reThanks again for the bett
Originally posted by node View PostSmilez & Jreed, use the link provided in post #1946 here, and download the .zip extract on a SDCard. Get the IP of the box and putty into it do not insert the SDCard as yet. after you are in, excute reboot recovery, the Android guy will come up and fall down, select wipe data/factory reset. When that is done insert the SDCard, putty back into the box and excute the same reboot recovery, the Android man will come up and load OE for you.
Yes, it did worked for me but I had to copy into my brand new SD Card and its working fine. However, I have formatted my last SD Card with ExFat. Do you know which type of format will work? ExFat or MS DOS Fat? I am bit confused here.
Thanks in advance and I really appreciate it for your kind help.
JR
There are currently 3592 users online. 0 members and 3592 guests.
