[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Can someone help me please.
I'm using OpenELEC-Amlogic.TV110.arm-5.95.5.2 on my S805 device.
I have a Mygica T230 TV tuner which is only supported on Kernel 3.19, since this is Kernel 3.10 it needs drivers. I looked at the drivers seem to be there but tvheadend doesn't see the tuner.
Code:[ 4814.995650@2] usb 2-1.4: new high-speed USB device number 9 using dwc_otg [ 4815.096587@0] usb 2-1.4: New USB device found, idVendor=0572, idProduct=c688 [ 4815.096619@0] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 4815.096632@0] usb 2-1.4: Product: USB Stick [ 4815.096644@0] usb 2-1.4: Manufacturer: Max [ 4815.096656@0] usb 2-1.4: SerialNumber: 080116
Code:OpenELEC:/var/media/mmcblk0p1-mmc-SD02G_0xa7060d97/test # lsusb Bus 001 Device 008: ID 1a40:0101 Terminus Technology Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 009: ID 0572:c688 Conexant Systems (Rockwell), Inc. Geniatech T230 DVB-T2 TV Stick Bus 002 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 002 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub OpenELEC:/var/media/mmcblk0p1-mmc-SD02G_0xa7060d97/test # lsmod Module Size Used by si21xx 8360 0 cbc 2022 0 dhd 626113 0 cfg80211 204928 1 dhd wifi_dummy 594 0 mali 162645 5
Also why am I getting massive amounts of screen tearing in the UI?
I have 2 M8 boxes from different manufacturers. I flashed them both. One is running great with Openelec (thanks codesnake) the other is bricked. I've tried everything to unbrick the last one. Any help would be much appreciated. I attached some photos.You may only view thumbnails in this gallery. This gallery has 5 photos.5 Photos
Originally posted by codesnake View PostYou said yourself that the tuner is supported only since kernel 3.19. So because your firmware has kernel 3.10, it is not supported.
The drivers can be backported and poking around in the kernel all the files required are there:
dvb-usb-cxusb.ko
si2157.ko
si2168.ko
dvb-demod-si2168-b40-01.fw
dvb-tuner-si2158-a20-01.fw
dvb-usb-cxusb.ko
si2157.ko
si2168.ko
According to the link the modules can be built using media_build for older kernels.
Hi everyone. I have been running Megatron Android for some time on my Amlogic S-802 TV Box (OTT, 2GB, square M8, round remote). I know Codesnake's ROMs work great on this device, and I would like to have a try on his imminent OpenElec 6, preferably by running OE from SD card (or USB stick) while keeping Android on NAND untouched. Could any experienced user please post a detailed procedure for the preparation of such a bootable SD card (or USB stick), aimed at running OpenElec for M8 directly from removable media, starting from Codesnake's ZIP or TAR files for M8, and not affecting the Android system residing in the unit?
There are currently 3482 users online. 0 members and 3482 guests.
