[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
    5.0.3 only shows two cores working also. Maybe it's only set to have 4 cores working for gaming.
      Originally posted by kraigtoft View Post
      Will this version be getting a new kernel upgrade or staying on 3.10.
      Hope I'm wrong about the cpu comment.
      The kernel will be updated only if Amlogic will release an updated kernel. Most likely Kodi shows wrong info about CPU.
        Aeon Nox shows right info and also while playing a video press the letter O if you have a keyboard. It'll only show 4 cores working.
        I have another OpenELEC Linux on my box and it shows 4 cores working. The MX2 will only show 2 cores working since it's a dual core.
          any chance of a 6.95.x beta build
            Amlogic 6.95.x builds will be released after each official release of 6.95.x by OpenELEC team.
              Hi again codesnake
              I assume by the replys that they are all working then. Sorry to have brought it up. Let's just hope amlogic release something like 3.18, I'd love the dvbsky s960 to work on these boxes. Keep it up mate your a legend
                It's something new about openelec repository codesnake?
                  i noticed an issue, DTS passthrough via HMDI doesnt work. just get no sound
                    Not so quick job. It requires new build.
                      What box? Please when reporting a problem mention what box you are talking about, so I'd not ask every time.
                        Hi again codesnake
                        I use dvbsky960 with minix x8 h plus. I add driver my kernel part and that's working no error.
                        That problem based amcodech and other kernel part of amlogic. Some channels hd and sd have no erors with openelec, openpctv and android. Some hd channel stutters . Mpeg2 channels frame skip.
                        a big problem of amlogic mpeg2 video quality of pictures very bad (hw decoding with amcodech) than other dvb receiver.
                        Indeed all chinese minipc cpu video pictures guality (mpeg2) very bad but Cheap
                          Sounds like there are a few minor bugs to iron out before I consider updating (still running 5.0.3 with 14.1 Helix on my M8 box, which is virtually flawless) but thanks for the update codesnake.
                            Hi taki
                            That for the info. I wouldn't know where to start for compiling drivers into a version of openelec. I'm sure it will get supported on these boxes eventually.
                              Firy setup ubuntu 64 bit on your pc
                              Git clone codesnake git
                              After add project/amlogic/patch/linux dvbsky patch
                              Goto your device folder open linux.conf.
                              Find dvbsky=m
                              After compile openelec. Activete vdr or tvheadend. Search chhannels
                                Thanks i know how to use Linux and might give ita try. I'll try to follow your instructions and also find a tutorial. I think one of the biggest downfalls of these devices is that there are no tutorials for beginners to having a go. Maybe if there was more info with how to's then these boxes maybe might have more people working on them. I've read forum after forum and there are people asking ask the time how to do stuff.
                                Sorry for the rant but just my opinion, would just be nice to have a forum on people wanting to learn to work on images. Boxes are becoming the thing now.
