[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Hi everyone
just my 2 cents about Openelec on a MXIII G n200 1gb-8gb: installed yesterday (downloaded from http://amlinux.ru/image/6.0.0/)
PRO
Installed correctly, boot fast as the speed of light, remote recognized, openelec fast as usual, lots of configurations etcetc
CONS
i've noticed the missing of Mediacodec and libstagefright from the Acceleration in video settings.... so, reading from an usb3 hd, the 1080p and h265s file are absolutely unwatchable (with kodi 15.2 on 106L1 firmware those files was almost perfect....
While watching a h265 file, the cpu where all around 1/3% usage
i'm not an expert, i don't know if the "problem" is the missing of those two codecs, but i sadly had to switch back to 106L1 firmware....
PRO
CONS
>Ok, great, waiting for your results
Originally posted by Blindseyed View PostIt just has the Amlogic also in 6.0.0.1 but I'm not having any issues playing any 1080 videos. You can always go back to 5.0.8 here http://amlinux.ru/image/5.0.8/
do your cpus work when you're watching a mkv or, like mine, they are stuck at 1/3% ? i think they should work if i'm using hardware acceleration watching a h265 movie.....
p.s.: do you have those missing codecs or it just works with the only one i saw (don't remember the name, i'm at work right now...)
Ok, i'll try.... which one do you suggest for my MXIII G n200 1gb-8gb amlogic s812?
My CPU usage is only at 1\4 but all 4 cores are running. If you're looking to mainly play movies from a hard drive then staying with the 5.0.8 would be fine I think, there's nothing wrong with that one at all. The amlogic acceleration is the only one in this build I'm using it and its fine. Did you try to turn off the acceleration, cuz sometimes that can make videos actually run better
all the 5.0.8 are for amlogic s805....can you suggest me which one for my s812?
i tried to turn off acceleration, it was ever worst.....
I'm not sure if the S802 and S812 use the same one. I think I read this thread that it works on both
Sorry, I know this question has been answered before, but the solution offered did not work for me this time. I've installed Openelec 5.0.8 on a M8 2gb/8gb android box and,when I play a video with hardware acceleration enabled, all I get is the amlogic logo on the screen. I updated to the latest (or what I think was the latest) version of android, but still no solution to this problem. I've done this before on other M8 boxes and they worked fine, but this is probably not an original M8, and that could be the reason why it can not be fixed using "standard" methods. If anybody has a solution I would appreciate any help I can get. Thank you very much.
There are currently 2801 users online. 1 members and 2800 guests.
