[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View PostHard to tell for sure without even seeing the box, but if it is G81REF then I think the builds for MX2 should work.
How do I install openelecI 6 copied the 3 files from the zip to a sd card and booted into recovery but nothing happened ,just recovery mode tried from sd card and nothing there.
Please help tell me how to install openelec.?
Originally posted by Freko106 View Post
In Kodi system info Amlogic Meson6 g02 customer platforem,, Mali-400 mp .Plus what I have listed the rest what I see in about mediabox.
Originally posted by Freko106 View PostI tried formating the sd card with fat and its starting now,ex-fat would not work,its installed ok but now wont boot up just the red light on remote wont turn it on.
What can I do?
Can anyone help.why has this happened I downloaded the correct version for my MX g18ref box,why did it install all the way then shut down and not start.
Originally posted by codesnake View PostThis means that your box is most likely not compatible. If you still can enter the recovery, then you should be able to reflash the original firmware, if you have it.
Please help.
It wont go into recovery anymore,it will not start ,the red light at the front is on but nothing on the screen.I dont have the original firmware,How can I get this fixed and get Android installed again?
Please help.
Originally posted by Freko106 View PostIf I get the correct firmware how do I get the box to startup as its doing nothing now.
What can I dp to get it to boot,even to recovery.?
PLEASE HELP ASAP/
Codesnake, Thanks for all the hard work!
I searched for quite sometime on this thread for a release of openelec for the M8s boxes with s812 proc. I found one at http://www.amlinux.ru/image/ and found a way to boot into TWRP (TWRP 2.8.5.0 MXIII Plus) on my box (Element Ti4) I haven't found the instructions on how to actually flash the image and any considerations that need to be made. I'm assuming, from my Android rom flashing days, that I just select the .zip that I wish to install. Is there anything else to consider?
Thanks in advance! I have a coffee with your name on it!
Originally posted by DukeKautington3rd View PostCodesnake, Thanks for all the hard work!
There are currently 4137 users online. 0 members and 4137 guests.
