[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
yes there isBugs are Sons of Glitches!
JustMe
hello, I've looked around but I cant seem to find an answer.
I have 3 M8 square boxes. I have been using Codesnakes software since the MX2. my problem is that one of the boxes gets stuck on the OpeneELEC logo after updating to 6.0
mysteriously, this same box is the only one that has a red light when its powered off. now I can reinstall 5.0.8 or even 5.0.3.
is there any info I can provide so you guys/gals can better assist me?
Thank you
Originally posted by mannyp View Posthello, I've looked around but I cant seem to find an answer.
Thank you
Originally posted by codesnake View PostVia recovery using ZIP package: https://github.com/codesnake/OpenELE....arm-5.0.3.zip
I was able to recover it to 5.0.3 and now its updated to 5.0.8
however, if I try to install 6.0 it freezes on the boot logo. I've tried via zip and as an update dropping the tar file on the update folder via samba
i was able to update to 6.0 on my box. i put it aside for a few days and tried a restore via zip above to 5.0.3.
i then updated directly to 6.0 and it worked. looking back, i don't know where that 5.0.8 came from. so that might have been the problem.
thank you codesnake
Helping a friend with an android box,s802 Mali 450 2/8 "mx3" running stock Fw.
I wanted to put openelec on this problem Is the kid wants to run the showbox apk not addon. Any reason why he couldn't just run showbox apk on this?
This is my first post here, I could use some help, what's the best build for this, the kid is a noob I am not. Ionamin box tonight. What are my options?
codesnake On the M8 with 6.0 I'm still seeing the occasional micro-stutter with 24 fps content and output. The video is butter-smooth, but every few minutes the screen stutters for a few seconds.
CPU load and network load are all within normal limits.When displaying the same content on 50/60 fps, there is just the normal 60-24 fps pulldown judder.
Is this a known issue? (openelec or kernel)
I've seen the same issues mentioned on some other Amlogic Openelec fora, but never found a real answer.
Originally posted by Dovedescent7 View PostHelping a friend with an android box,s802 Mali 450 2/8 "mx3" running stock Fw.
Originally posted by sentry23 View Postcodesnake On the M8 with 6.0 I'm still seeing the occasional micro-stutter with 24 fps content and output. The video is butter-smooth, but every few minutes the screen stutters for a few seconds.
Originally posted by codesnake View PostI don't see any problems with 23.976 content on Amlogic S802-based boxes. With "Adjust display refresh rate to match video" option enabled it should play 23.976 videos just fine.
Output is set to Adjust display refresh rate, and the switch to 23.976 goes as it should. Just every few minutes it looks like a few frames are duplicated, as if something is trying to sync the stream. I'll make a video to show the issue.
Originally posted by codesnake View PostIt is not possible to run APKs on this firmware. It is not Android.
Originally posted by faresqc View Post
Hello,
Did you release this update? Because I don't find it in the first post
Thank you
There are currently 3676 users online. 0 members and 3676 guests.
