[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by Stu308 View PostYes, of course it is. it's ok i done it. I had to extract the md5 file and put it in update folder seperately. It's all done now. thanks for the help.
hi
I am new to this and would appreciate any help, got a mx box with G18REF board(system mbx ref board(g18ref), currently have the stndard 4.2.2 that was shipped with the box
Wwhat i have done is downlaod the full installation for my box from the link on the front page
1. Copied it to the USB and via mx menu(sys Update, chosen the OpenELEC-Amlogic.MX2.arm-6.0.1.zip file(this fails saying check file vailidy)
2. Then tried to extract the zip file and then choose via same menu OpenELEC-Amlogic.MX2.arm-6.0.1-update.zip and this works and reboots, after reboot is says initialization failed and gives me options
like data/wipe tried all and all fails and box goes back like a new box
Sorry for the questions it must be simple any guidance appriciated
And do the same.. Getting into recovery and
Installing OpenElec on these boxes is a little different.
Thank you
This wvide was perfect https://youtu.be/jKtL6sKfDwI
to update i used this link
Now to start learning about adding repo to my setup and watching via kodi
thank you again
thank you again
Just copy and paste into your current openelec update folder follow instuctions from this video:
Originally posted by Nemsis72 View Post
Cool im glad u figured it out, if you want to update to kodi 16 jarvis here is the link to it:
https://youtu.be/bIrk-1WPe4A
working great! thanks.
MX2 GBOX Kodi 16.jarvis update tar: https://mega.nz/#!Yd5HhSIZ!BPv_AvYiw...jX4JS0dNs6I8ZgLast edited by Nemsis72; 12 May 2016, 11:51.
There are currently 4564 users online. 3 members and 4561 guests.
