[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by startreksuite View PostI tried updating with your OE 7, and received an error message saying that there were some missing files, something like a m5 checksum.
Originally posted by Nemsis72 View PostThats the same box i have and my build if working awesome on it. Havent had a problem with my build since I've compiled and installed it...
Originally posted by Friffy1 View Post
I'm certainly glad it's working for you. But are you saying you're out of ideas on why your build won't work these two boxes? (Also, CodeSnake's 6.0.3 build.) It's weird the Ember build works fine. I only tested that one on box, but it worked great. Just it's only Kodi 14.2. Also I just tried reverting back to Matricom's Android build again and that still works fine, too. This is all very odd.
Originally posted by Nemsis72 View Postno u dont have to go to 4.2.1 just clean flash OE 7.0 after flashing ember zip.
Here it is: https://mega.nz/#!8cgXjRhI!mu8wGyY14...ujItOf8HdrXS2E
Extract all 3 files to a fat32 formatted sd card not usb...
But before you do atemp to clean flash my zip u are going to have to flash this ember zip.. here: https://mega.nz/#!hN5mWShZ!Qnp3RB-Ub...3kgwYBxqjJEzo0
To format your nand to proper sized filesystem after making a mess with ur tar update fiasco.
After a clean boot from ember, turn off then flash my zip file.
And if you want to revert back to stock android you are going to have to flash this zip. https://mega.nz/#!QUhiEQiS!wY-E2uWBk...KOkIkvNHLhBwBc
In order to reformat those same partitions for its included android zip.... Goodluck!!!
According to this, I will have to install ember, then your zip file. Is this correct?
It helped alot because it formated the nand partitions that i screwed up when trying to revert back to OpenELEC after messing it up trying to revert back to android without reformatting the nand partitions for android install. OpenELEC formats the nand differently than android does. That why in the post you will see a revert to android zip from ember. It does not matter if you have OpenELEC you can use that zip to reformat your nand and revert back to the included android installation zip.
Yeah. Im at a loss why it wont work on you boxes.. because not only is working on my box but also my family members also as well as my co workers box... Sorry bro...
No worries. So, strangest thing. That box is now bricked. Light comes on, but no display at all. Can't get into recovery. I don't know what the heck to make of all this. Have you seen MX2 boxes that won't even get into recovery? Any ideas as to a fix?
There are currently 2069 users online. 0 members and 2069 guests.
