can you contact me pls.
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by Nemsis72 View PostMX2 GBOX Kodi 16.jarvis update tar: https://mega.nz/#!Yd5HhSIZ!BPv_AvYiw...jX4JS0dNs6I8Zg
I downloaded and installed this on a GBOX MX2 (8726MX), but Wifi is running super slow.
Ethernet works just fine.
I am an advanced user, and the router is 2 feet from the unit.
Any ideas?
Any ideas?
Originally posted by Nemsis72 View PostI have no clue. Ive been running this same rom since I've compiled it. Some of my friends and family members are running this same rom also without issue. Must be at your end. Check your bandwith, link speed, signal... add an advance settings xml or revert back to 15.2.
Speed, bandwidth and signal are not the issue.
I have other different boxes not running this firmware and they run fine.
What do I need to add to my advancedsettings.xml?
Going back to 15.2 is not an option as some addons are no longer compatible and are having Dependencies issues.
Originally posted by IMFan View PostJust wondering, i am running the 15.2 version codesnake cooked up which is excellent.
Did i understand correctly Guest and is your 16.0 built based on codesnakes work or does it have another base?
You can as i have on my box, an advance xml file. Go to maintenance tool, then system tweaks, then click on create-edit-advance-settings tab. Click on edit settings then on network settings then network again. Click on cachmembuffersize and set to 52,248,600 Wich equates to 50mb. Your box will use 150mb. Of ram for video caching. Then click on buffermode set to 1, and lastly readbufferfactor set to 20, after setting it, back out 3 times. Then click on write xml file. once done reboot device, try out again. This is the same settings i have on my box...
I tried the advancedsettings.xml tweaks and that did not work.
I tried the unit on Wifi at 3 different locations and all the same result.
I will just run it on ethernet.
Either way great work. The unit runs like a champ with 16.0 installed using ethernet.
Originally posted by Sooperfly View PostI tried the advancedsettings.xml tweaks and that did not work. I tried the unit on Wifi at 3 different locations and all the same result. I will just run it on ethernet. Either way great work. The unit runs like a champ with 16.0 installed using ethernet.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
What a dumb ass... didnt read it write and updated openelec M8 version with Nemsis72 jarvis built, i was with an hardon for jarvis... now i messed up and the box enters on recovery mode (lucky eheheh) what should i do? reinstall M8 version with sd card (i have to figure this out again, i will be a eternal noob) or am i able to recover the previous installation with all my configs?
My box is an mxiii 2g... M8 S82 i am almost sure, becouse the m8 update with isengard worked fine.
thanks for the help in advance.
Originally posted by Norin View PostWhat a dumb ass... didnt read it write and updated openelec M8 version with Nemsis72 jarvis built, i was with an hardon for jarvis... now i messed up and the box enters on recovery mode (lucky eheheh) what should i do? reinstall M8 version with sd card (i have to figure this out again, i will be a eternal noob) or am i able to recover the previous installation with all my configs?
There are currently 5159 users online. 1 members and 5158 guests.
