[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Very nice indeed!!! Thank u Codesnake. I have a "Xunity Aurora" box the version before the android version. It was shipped with kodi 13.2. I downloaded the T8, https://github.com/codesnake/OpenELE....arm-6.0.3.zip and extracted to the root of the SD-card. Went into . Xunity Maintenance and to "All Linux" and did an update and after 15 seconds I was up and running with openelec.
Thanks codesnake for a great build. My gbox has been running great since I upgraded to OpenELEC. I just had one issue with installing it, for some reason whenever I was trying to flash it onto my box it was keeping getting stuck on the logo screen. I wasn't sure why since I was doing a fresh install but I was able to fix it by making changes to the "factory_update_param.aml" file.
I added these lines:
--show_text
--wipe_data
--wipe_system
--wipe_cache
--update_package=/sdcard/OpenELEC-Amlogic.MX2.arm-6.0.3-update.zip
This way I was able to wipe any old data and cache and afterwards it installed fine. Figured other people might find it useful too.
Hi I have a bricked M8 ver 8.9 20151031.I have tried to reburn using amlogic usb tool. I have no problem getting success connect but it hangs and restarts at i% with the following code logged in red type.
[0x10105002]Romcode/initialize DDR/Read initialize status/USB/C....
Has anyone successfully recovered this box from a soft brick and what software did you burn. I want to install Openelec on this box as the original software is total crap. Thanks in advance
Hi everyone! I just decided to update to openelec 6.0.3, which worked, but was bothered by the icons not updating. I went further and dropped Nemsis's .tar file, and it installed no problem. I don't know if this will be a problem if you use wifi. I have mine hardwired, and so far so good. Currently working, crossing fingers.
Originally posted by Flashaholic View PostUpdated from Codesnakes 6.0.3 to Nemesis Jarvis . Works fine. Thanks Codesnake and nemesis for ur work.120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
M8 TV Box Codesnake's OpenElec 6.0.3
Tronsmart MXIII+ (v108L1) + KODI 16.1 (Jarvis)
Originally posted by jopereira View Post
Where can I find the Nemesi's build you use?
New install Zip file here:  https://mega.nz/#!8cgXjRhI!mu8wGyY14...ujItOf8HdrXS2E
Originally posted by Flashaholic View PostThe nemesis build is only for MX2 G18 ref Box.120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
There are currently 1934 users online. 0 members and 1934 guests.
