[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View PostI don't know, I don't have any problems with H264 HW decoding, and it seems others too. What logo do you see during playback? pls take a photo.
Originally posted by gtvdev View PostThanks for replying. Here;
http://i.gyazo.com/37bc94152f6b6b4e7a0f83d1a6220af6.png
Originally posted by slikmik View Postthanks for your effort.
but when i try to play something it just displays the m8 s802 logo
sound is there , tried all various settings in video acceleration still nogoLast edited by gtvdev; 01 March 2015, 14:51.
I've noticed on the Russian forums that many people are having issues with HDMI-CEC working, causing the TV's Power-Off to Power-Save the OpenElec box.
However, the TV's Power-ON does *not* restore the OpenElec box.
Again, this is documented on the Russian forums, but I do not speak Russian.
I also read that someone has added an option to the Kodi menu that allows CEC to be enabled/disabled, but I don't see that either.
I am running v5.0.3 for the Amlogic s802 and still have this issue.
Thank you in advance for any suggestions!
Originally posted by wpb View PostI've noticed on the Russian forums that many people are having issues with HDMI-CEC working, causing the TV's Power-Off to Power-Save the OpenElec box.
Originally posted by wpb View PostHowever, the TV's Power-ON does *not* restore the OpenElec box.
Originally posted by wpb View PostAgain, this is documented on the Russian forums, but I do not speak Russian.
Originally posted by codesnake View PostCan you send an video URL to reproduce the issue?
This is on an M8N pcb v1.00
Genesis -> Walking Dead -> S05E11 -> Ororo stream. It's the same with all videos ofcourse.
Even on Dim screensaver, i see the M8 logo on the upper left part of the screen.
EDIT: This does not happen with software acceleration.
Hi codesnake, could you take a look on this issue/feature and give quick impressions ? https://github.com/codesnake/OpenELEC.tv/issues/47
Thanks for your work !
Power On with remote doesn`t work
Hello I´m new here,
i have the Beelink M8 8GB Version with 2GB Ram and i flashed the OpenELEC-Amlogic.M8.arm-5.0.3.zip. All works fine. But i can`t power on the box with the remote only with the button at the box.
Does anyone have a solution for it?
THX
THX
I have the same problem also with a M8 player. All work fine, using the TV's RC, except for the power on function.
The nice solution would be to map a key on the RC to power on the M8, but I don't have the knowledge for this, so I just used a simple noobish approach:
- buy usb to power 5V , 5,5mm adaptor and power the M8 from one of the TV's usb ports, or
- buy a remote controlled power outlet and plug the M8 in it, so it can be powered on/of from there.
Both solutions work well and either of them will do till I'll find someone able to map my RC.
There are currently 2991 users online. 1 members and 2990 guests.
