Edit: With my M8 Remote i can power off the box
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Referring to @CodeSnake's reply regarding CEC being a feature, not a flaw:
Originally posted by codesnake View PostIt is not an issue, it is by design.
As far as I know Amlogic SOCs don't support CEC poweron.
How can it be a feature, that as soon as my TV turns off, the box goes into Powersave, permanently. What that means, is that if I want to watch Kodi again, I must manually walk to the box and press the physical power button to wake the box.
If you are saying that CEC-Power-On is not supported by the AmLogic chipset, why would Power-Off (Power-Save) be implemented? If one isn't available, why would the opposite be available?
In the Russian forums, there were several posts discussing this and it was mentioned that this was fixed in 5.0.3, or that there is a new menu option under Kodi to disable CEC. I've looked everywhere and cannot find this menu option.
Thank you in advance for any ideas.
Originally posted by kaerichi View PostThanks for the response, but do you really think it is the key mapping of the remote? I thouht the power command is a toggle command power on/off
Since in openelec/configfiles/rc_keymaps is a readme that says "put your own key files here", I suppose it can be done.
Originally posted by wpb View PostReferring to @CodeSnake's reply regarding CEC being a feature, not a flaw:
I don't understand, I must be missing or misunderstanding something huge.
If you don't want the player to be shut off by CEC, just go in the TV's CEC settings and disable the power off function.
Originally posted by Kiralina View PostI'm not sure, but my M8's RC doesn't work at all now. I control Kodi with the TV's remote and all is fine, except for powering on M8 (CEC is not supposed to do this).
Originally posted by Kiralina View PostThis is because you don't really power it off, you just put it to sleep and somehow, the wakeup function doesn't work.
Openelec can load another remote.conf from config folder. So you can use any other (MCE-)remote with the box. Problem is that your remote.conf is only loaded on startup. So the box won't wakeup with this remote because it uses still the remote.conf openelec was compiled with. And because openelec is a readonly system you can't manually change this "hardcoded" remote.conf.
I don't know for which RC codesnake made his releases for because I don't use one but I think that is mostly the problem for the impossibility to power on the device.
CEC (and other things) seems to be still buggy in 5.0.3. I think most were fixed in the latest openelec 5.0.5.
Originally posted by MikeD View PostOpenelec can load another remote.conf from config folder. So you can use any other (MCE-)remote with the box. Problem is that your remote.conf is only loaded on startup. So the box won't wakeup with this remote because it uses still the remote.conf openelec was compiled with. And because openelec is a readonly system you can't manually change this "hardcoded" remote.conf.
There are currently 2746 users online. 1 members and 2745 guests.
