[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View Post[*]for updating the exisiting installations: https://github.com/codesnake/OpenELE....arm-6.0.0.tar[*]for new installations from recovery:
To note: I am currently using the M8 versions found on 'http://www.amlinux.ru/image/6.0.0/ on my Matricom G-Box MXQ. Might your M8 link and their's be the same?Last edited by inameiname; 09 December 2015, 12:38.
Originally posted by inameiname View Post
Just curious if your M8 tar and zip will work on the official Matricom MXQ (with K200). I read a few pages above you are not currently supporting the MXQ, but it was unclear if it was this MXQ, or the MXQ listed with HD18g. I am guessing the latter since you listed an MXQ with an Amlogic S805 SoC on your first post (that is not the Matricom G-Box MXQ).
To note: I am currently using the M8 versions found on 'http://www.amlinux.ru/image/6.0.0/ on my Matricom G-Box MXQ. Might your M8 link and there's be the same?
those are Kerbers builds and they are different.
Ok, thanks. Do you happen to know what is different between them? Perhaps which works better? Also, regardless of their differences, if Kerbers' M8 build works on my Matricom G-Box MXQ, do you think Codesnake's would as well?
not sure i dont have that device, i do know they are different, not sure on the differences or the compatibility with your device, if your interested in doing some research on kerbers version check xbmc.ru or http://amlinux.ru/image/6.0.0/ (use google translate,lol) but since this is codesnakes thread thats all a bit off topic, it does look like theres a build for your box tho
Hi. First post and total Noob!
Not particularly knowledgeable on this subject. Managed to install OpenELEC on my MX2 some months ago. Worked awesome. Made minor changes to network (changed ISPs), then had all sorts of add-on errors in Kodi.
Figured an update was due. Found these links and tried install. System destabilised entirely (see attached screen shot). Worked like a charm briefly yesterday but every time I restart MX2,i need to reinstall Kodi, configure, etc (start afresh).
Can anyone here please point me to 'The Idiots Guide' to resolve this easily? I'm really missing my telly :-(You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello. How to change M8 remote config? OpenELEC for Amlogic 6.0.0 with Kodi 15.2 Isengard
I tray to put new remote.conf on /storage/.config but after restart nothing change :/
Original remote.conf is located at /etc/amremote/remote.conf but i can't change it.
Any idea?
On older version I could do that, and add new button like play, pause...
There are currently 1278 users online. 1 members and 1277 guests.
