[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Hi
I have this box http://www.aliexpress.com/item/surpr...759867713.html
I installed OpenElec http://amlinux.ru/image/6.0.0/OpenEL...0.2-update.zip.
The application works perfect except the IR remote control.
I tried some of the solutions suggested by baal77 and codesnake but no luck (maybe I was going the wrong path).
Can anyone suggest a solution for this problem?
Thank you.
Thank you.
If you are interested to porting the openelec to some newest amlogic s905 tv box? if so, contact me, I would love to work together to bring this happen.
Eric
Looking for developers
codesnake
If you are interested to porting openelec to the amlogic s905 tv box? We would love to support some device for you, contact me via PM if you are interested.
Hi
Thank you.
For amlinux builds ask the one who released them. It is wrong place.
Can anyone point me to an OpenElec that can work on this box (http://www.aliexpress.com/item/surprise-Quad-Core-Amlogic-M802-2-4G-5G-Dual-WiFi-2G-RAM-16G-ROM-Mali450-smart/1759867713.html) ?
Originally posted by codesnake View PostThey could be similar externally, but different internally. But on the first sight looks the same.
2, OS: Android 4.4 KitKat
3, DDR3 2GB RAM ,8GB ROM
4, Support 2.4G/5G Dual Wifi
5, Support Bluttooth 4.0
6, Support 4Kx2K HDMI Output
7. Support play 3D blu-ray and Blu-ray ISO format video and movies directly.
8, KODI Pre-installed and play perfect
9, Pre-installed Famous APK & ADD-ONS
Do you think they are the same?
Thank you
Originally posted by Fed10 View Post
The specs are: 1, Amlogic S802 M8 Quad-Core Cortex A9 2.0GHz
Thank you
Originally posted by codesnake View PostSpecs may be the same, but board is different.
Where could I buy M8 or T8 or G18? Do you could give me a link/shop, please?
Thank you
EDIT: this (http://belinkteck.en.alibaba.com/pro...836.128.DbDh3D) could be ok?
Which board has M8 that you've mentioned in first post?
Thank you
There are currently 4881 users online. 0 members and 4881 guests.
