[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by IMFan View PostHi there,
like you, i purchased the PCTV 292e dongle, and was planning on running it in my MX2 directly, which i'd like to say, has pretty much come alive once i got rid of the Android firmware (Thank You Codesnake!)
Anyway, i found a really nice way which works perfectly for me.
It seems that DVBLink is a perfect match with this tuner; i just downloaded the latest BDA drivers from the PCTV website and went and installed DVBlink components on a (any) Windows backend. Plugged the tuner in; let it scan and installed the DVBLink client in XBMC. Works really great and all recordings are on my laptop to watch when i am away from home ;-) You could also run the backend on a NAS for example.
Only one ' downside' as it's not free, but you can activate a 20 day trial.
Originally posted by codesnake View PostThat's because Stane's Linux uses software decoding for MPEG-2 videos, but OpenELEC uses hardware decoding, and I can confirm that MPEG-2 hardware decoder on S802 has problems with some MPEG-2 streams.
Codesnake, is there a way to select software decoding for Life TV + Hardware decoding for other's sources?
For me, disabling amcodec seems to give smoother playback in live TV streams (eg Pak India) but enabling it gives smoother playback in HD movie streams (eg Cartoon HD).
I'm still on the Gotham ROM btw, no problems. I don't mind toggling. Thanks again codesnake.Last edited by dave_leeds; 16 November 2014, 01:52.
Try this addon : Palco TV
Try this addons, Palco TV, http://palcotv.blogspot.com , use google traslate
Originally posted by protecteur View PostHi! Codesnake is there a way to get Iptv simple client to work with OpenELEC 4.2.1 with XBMC 13.2 Gotham (new MTD) on the GBOX MX2?
I love this version on my mx2 and it works awesome and great work. the only thing is that I cant get iptv simple client enable. As soon as you try to anable it in the pvr client list you get error and it disable itself.
Any help would be much appreciated!
Thanks in advance.
Thanks in advance.
Originally posted by Jarv1ss View PostCodesnake, is there a certain firmware we should flash your OE on top of or does it matter. The issues I had on my M8 don't seem to be happening to anyone else. I flashes a stock firmware from grant an and then 4.2.1 but it sticks in the openelec slash screen.
This is something common and many users are effected by this issue on MX and M8v(more on MX).
Apart from this error there is another error which says something like "Failed to start XBMC hacks" and once you are stuck there, the only way is to reinstall the ROM but you end up loosing you xbmc data which isn't that good. I have pointed out this issue earlier as well but no one has noticed it so far.
I hope this could be fixed.
Originally posted by sukhbeer View PostThis is something common and many users are effected by this issue on MX and M8v(more on MX).
Originally posted by Daaave View PostThanks very much for taking the time to reply. I might have to go that way I think. I have a roof antenna and will have to get another feed to where my PC is. Probably worth doing it though.
I am currently thinking of buying a second pctv stick to be able to record and watch at the same time or watch a different channel on another device.
The program supports 8 tuners ;-)
Same problem here
Originally posted by De Bouwer View PostI did some testing today.
I went back to android today om my M8.
All was fine. 180p and cec was working.
I flashed kodi openelec again and only 720P and no cec ( all options where grayed out. so i cannot chance it)
I post a dmesg in a attachement maybe you can see something is wrong.
I realy like your stable version. but not having 1080P is anoying. cec isn't that important for me.
Thanks alot for your help.
[ATTACH]8803[/ATTACH]
I have the exact same problem on an M8 Square Box, NO CEC ( Greyed out NO 1080p
Tried on cec-client on the cmdline, but little debugging without any outcome !
What can we do ?
What can we do ?
No CEC & 1080P
Originally posted by codesnake View PostYou can send me your dmesg output, baybe I'll find the cause of your issue.
Codesnake,
See attachment.
And thnx m8 ;-)Attached Files
My dmsg also
Originally posted by deffcon View PostCodesnake,
See attachment.
And thnx m8 ;-)
\here you have my dmsg also again, maybe you can fix it.Attached Files
There are currently 2790 users online. 0 members and 2790 guests.
