[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
    Here is my build for M8 , built from kerbers Openelec with new kernel
    and 5.0.5 build, built from Codesnake Openelec
      Originally posted by jeep52 View Post
      M8 android tv box is 32 bit or 64 bit with openelec thanks if someone can helpme.
      32-bit.
        M8 S802 Amlogic Dead
        I trying to get to life a MTBox. unfortunately I tried to flash with a wrong firmware and now, I cant install any firmware with standard method (.zip, factory_update_param.aml, recovery.img) the devise stop process at 10 % aproxly.
        on the other hand I tried too with method with
        USB_Burning_Tool but the devise can turn on if it is connected via USB with PC.
        So, I learnt I can burn a SDcard with bootloader.bin thru
        bootcarmaker program, but I can´t find a ROM .img with corresponding bootloader.bin. What can I do now?
          HW DECODING ISSUE.
          The dmesg log:
          Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
            Just extract the bootloader.img from corresponding ZIP file and rename it. It is the bootloader.
              Originally posted by smilez View Post
              Well this work for mac??
              Here it is for mac:
              Download the latest version of FileZilla for Mac for free. Read 109 user reviews and compare with similar apps on MacUpdate.
                https://www.dropbox.com/sh/sng7yawj3...FTmKZUVYa?dl=0
                Thank you. I'll try them both.
                  Will that work on T8 box. Its same hardware as M8 i think .
                    Codesnake, a big thank you for this ROM, I loaded it onto my MX2 and is by far the best I have tried, a great bit of work and very much appreciated.
                    Stay safe.
                      Stay safe.
                      Thank you for your support.
                        No, really, Thank you
                          In need of expert advice
                          Hi Mate
                          How do I get the following firmware: -KOT49H.20141227 test-keys ?
                          A point in the right direction would be much appreciated. I've been searching the net like crazy so links are most welcome.......I have this on 1 of my M8 boxes and would like to add it to my other one. I've found some similar but I have remote issues not turning on/off when updated. Is it possible for me to copy firmware from 1 device to another?
                          cheers
                            Many thanks codesnake .
                              Many thanks Jonke.
                                I extract this bootloader and renamed. Then burned in a sd card, load then ROM and nothing. Stopped the process at 10 % aproxly
