I managed to update to kodi with the .tar file in the end. My problem now is that my HW acceleration does not work on Kodi. I get black screen. When i switch to software acceleration everything is ok. Is there any way to fix it?
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
I have an M8, currently on XBMC 13.2 and im trying to update to the new version. I download the .tar file, extract it in my FAT32 sd card. I boot the M8 into recovery but it never starts the update. It takes me to the recovery page. When i try manually to locate the update file i get the error of "no such file or directory". Any ideas what im doing wrong?
I managed to update to kodi with the .tar file in the end. My problem now is that my HW acceleration does not work on Kodi. I get black screen. When i switch to software acceleration everything is ok. Is there any way to fix it?Last edited by kakoskm; 05 April 2015, 17:55.
Originally posted by kakoskm View PostI have an M8, currently on XBMC 13.2 and im trying to update to the new version. I download the .tar file, extract it in my FAT32 sd card. I boot the M8 into recovery but it never starts the update. It takes me to the recovery page. When i try manually to locate the update file i get the error of "no such file or directory". Any ideas what im doing wrong?
It's the zip file you need to extract to your sdcard not the .tar file. The .tar file is for manual update through samba share.
Originally posted by MikeD View PostTry updating with zip file in recovery. That should work.
I manually select update from sd card but the files are not recognised from the system.
I would really appreciate your help as i have been trying to update for days now with no result.
The error i'm getting when i try to update manually from Recovery is the below:
E:Unable to mount '/sdcard' E:Unable to mount '/data' E:Unable to mount '/sdcard' Installing 'external_sd/s89_root_update.zip'... set_perm: some changes failed E: Error executing updater binary in zip '/external_sd/s89_root_update.zip' Error flashing zip '/external_sd/s89_root_update.zip' Updating partition details... E:Unable to mount '/data' E:Unable to mount '/sdcard' ...doneLast edited by kakoskm; 08 April 2015, 07:07.
Originally posted by kakoskm View PostHi MikeD. I have tried to update with the zip file but it didn't work. I extracted it in my SD card, i hold the recovery button in the A/V port, the device boots but it doesn't start updating, it stays in recovery.
Just unpack this file from OP and copy the extracted files to root of your sdcard. If updating don't start automatically after booting into recovery select "Update from EXT" and choose file "OpenELEC-Amlogic.M8.arm-5.0.3-update.zip". If that don't work maybe try using another sdcard.
Originally posted by kakoskm View PostThanks for the help MikeD. I will try tonight and let you know.
Unfortunately, my HW acceleration didn't work. All videos are black. In order to be able to see videos i need to go to System - Settings - Video - Acceleration, and deselect the option "Allow hardware acceleration (amcodec).
I would really appreciate any ideas.Last edited by kakoskm; 09 April 2015, 07:00.
Originally posted by kszaq View Post
ACEMAX XBMC KODI Amlogic S922X S905X3 S905x2 S905Y2 TV Boxes x96s S912 S905 TV Box M8 TV Box S805 TV Box m8n tv box MXQ PRO 4K
There are currently 4925 users online. 2 members and 4923 guests.
