any advice?
NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini
Re: NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini
I think if you can get to recovery you should be able to get to boot loader/flash mode,
Press and hold power for 10 seconds to force the cube off.
Press and hold vol +
press and hold power for three seconds
Release power and then release vol +
The tab should now have a black screen and be detected by your PC.
Now try and flash the ROM.900Supersport
freaktab developer
finaly I flashed my cube
and I have two more questions, i used yours rom to flash to 1.05 and its great but the keyboard which is instaled is not working, i downloaded swype, but the original keyboard is still showing errors....
and second question is if is normal, that my cube is constantly rebooting if charging...
Try removing LatinIME.apk from /system then re-boot. I use esfileexplorer for these sort of changes, you need to go into settings and enable the root options.900Supersport
freaktab developer
Originally posted by 900supersport View PostGood you got it flashed. The tB should not continually reboot during charging, it will turn on and boot if it's off.
can't unbrick my minicube
I'm trying to get my tablet back (it's brick) and when i short the pin it says "found rk android maskrom rock usb" and when i'm trying to erase the nand or flash the nand there's a message error: maskrom must choose loader for erasing.
I've done this before and it was working...
What does it mean ?
Txs
Try checking bootloader before erasing idb then clear the check before flashing.900Supersport
freaktab developer
Yes until I moved on to 3188 based tabs it was my main tab. My daughter now has mine and gets good use from it.
Sent from my XT890 using Tapatalk900Supersport
freaktab developer
Hazardous ROMing
Hi 900 Supersport !
I've succeeded in re-Roming my Cube U30GT-Mini
The result is excellent. Thank you for your efforts.
But the operation was touchy and hazardous, and I could not remember how I had found the right way.
So, I decided to make a new installation to see how to redo it in a straight and safe way.
But It was impossible !
The main issue stays in the connection between Pc and Tablet.
Sometimes it works, sometimes it don't.
It's probably not a cable issue, but a question of drivers.
Finally I'd to abandon my project for the moment.
I shall revert.
That does sound like the cable, try different cables and USB ports.
Sent from my Nexus 7 using Tapatalk900Supersport
freaktab developer
IMHO it is not related to cables. I've tested half a dozen of cables with mitiged results.
With the same cable sometimes it works, sometimes it does not.
I suspect the drivers being not adapted or reliable.
I've carefully read all messages related to this tablet and I can't imagine that there are so many defective cable met by so many persons.
Anyhow I thank you for your efforts.
There are currently 2359 users online. 5 members and 2354 guests.
