NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini
what tablet have you tried to flash and with what ROM?900Supersport
freaktab developer
everything there seems to be failing. You seem to have attempted to flash multiple times, and by the looks of things you have selected bootloader as well, this is not selected by default.
can you still put the tab into flash mode. If so try flashing using a different usb cable and a different usb port. Also see the don't panic thread.
let me know how you get on.900Supersport
freaktab developer
Originally posted by 900supersport View Posteverything there seems to be failing. You seem to have attempted to flash multiple times, and by the looks of things you have selected bootloader as well, this is not selected by default.
does that mean the cube works now?900Supersport
freaktab developer
sleep of death
Did anyone else encounter sleep of death? i put my tablet to sleep and often it does not wake up on power button press. If i am lucky after watiing for around 20 to 30 seconds it will wake up. Is this a common problem, shld i rev up my min CPU clock speed to a higher value? currently i am testing out using softlocker to prevent this problem, will see how it goes
Re: NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini
I've never had this on my mini900Supersport
freaktab developer
Originally posted by kyo171 View PostDid anyone else encounter sleep of death? i put my tablet to sleep and often it does not wake up on power button press. If i am lucky after watiing for around 20 to 30 seconds it will wake up. Is this a common problem, shld i rev up my min CPU clock speed to a higher value? currently i am testing out using softlocker to prevent this problem, will see how it goes
Never = not wake up
[QUOTE Originally Posted by kyo171
[/QUOTE]
I had the same problem
I use two software : "Wake Lock" and "Antutu"
The first is to prevent the tablet to turn off sleep mode (the software start at boot).
the second mange the CPU Frequency.
I have no problem...
Is it possible to flash the U30gt-mini with the U9GT4 soft?
Because the U9GT4 has Jelly Bean.
I think that the U9GT4 is the same as U30GT-mini with only 8G of memory
Here the link for the U9GT4 ROM: http://www.51cube.net/ch/DownShow.asp?ID=83
Thinks for your answer.
If I can get a download of that I will take a look at the weekend.900Supersport
freaktab developer
Great stuff, let me know. I'll make up a Rom for it anyway.900Supersport
freaktab developer
There are currently 2608 users online. 3 members and 2605 guests.
