I used a quick and dirty method to jump on the train : git clone;
but I think using repo init & syncs would have been better;
best would probably be to multicontribute to a single shared git repo,
but I'm not familiar with that (yet),
if anyone has enough experience, please suggest the correct way of working as a team.
tks
tks
Git Pull (Git fetch + git merge)
1. tried different gyro settings
2. removed angle driver from non-booting 1.04 kernel
3. first use of differential coding - note to devs - select model name in system type
Pushed code to git so that Raxy / steve / maakie can follow same style
SteveJC / Raxy,
If you have M7Pros it will be easier for you to take over and finish this off. What needs doing is:
1. setting the correct orientation params in the L3g driver within the ds1006.c source. Probably trial and error
2. Fiddling with the VT TS config params and the init values to get the touchscreen spot on
3. Amending the camera params to use the right GPIOs
Where you change code can you wrap with pre-compiler defines (CONFIG_PIPO_M7PRO) please?
Link not yet working
I'm trying to recompile it but get errors in board-rk3188-ds1006h.c
is there a simple efficient solution to catch stderr and stdout when running make kernel.img ?
I'd like to save all the messages (mainly warnings) coming out.
this works...
make kernel.img > makekernel.log 2>&1
