[Pipo-Project] M7Pro kernel
    Got it !
    so you need to replace the dat file by the one in the previous thread
    I compile with ctx36_ts (VTL) driver with this dat file
    For Config , You need :
    reverse X axis not checked
    reverse Y axis checked
    swap X/Y not checked
    And new point checked too
      Whoop whoop - so build yourself a ROM now!
      Excellent
      Donate to Finless
        Excellent
        don't have much time today but will try.
        So to build it, I need the config for M7 pro and add GPS support that's all ?
        I have problem while enable Bluetooth :
        here is dmesg : M7_newkernel_bt.txt
        and logcat : M7_newkernel_logcat_bt.zip
          here is dmesg : [ATTACH]9656[/ATTACH]
          and logcat : [ATTACH]9657[/ATTACH]
          Finally after reflash Bluetooth is ok now !!!
          I get problem with brightness, it 's reversed and if you pull cursor to 80% or more, the screen is black !
          Automatic brightness is maybe not working : I get black screen , maybe due to the same problem.
            Great !
            I think auto brightness is supposed to work but has never and will never work because of the hardware and in the stock firmwares.
            Do not bother fixing it.
            Now regarding usb audio,
            can you try if USB-DACs are now plug and play ?
            tks ! now waiting for git to be updated with the future stable sources to build also my own kernel !
              That's what we got the sources for!
              Donate to Finless
                Steve
                I'll checkin my latest tonight and then you can build any changes you need back in. Okay?
                Donate to Finless
                  Steve
                  OK
                  I have no OTG (it's working on stock kernel) , so no USB audio
                  Can someone test that
                    OK
                    Your DMESG
                    Code:
                    <6>[    2.992279] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
                    <6>[    2.994677] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf200000
                    <6>[    3.205263] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
                    <6>[    3.205303] usb20_host usb20_host: DWC OTG Controller
                    <6>[    3.205408] usb20_host usb20_host: new USB bus registered, assigned bus number 1
                    <6>[    3.205469] usb20_host usb20_host: irq 49, io mem 0x00000000
                    <6>[    3.205537] DWC_OTG: Init: Port Power? op_state=1
                    <6>[    3.205562] DWC_OTG: Init: Power Port (0)
                    <6>[    3.205621] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
                    <6>[    3.205659] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                    <6>[    3.205698] usb usb1: Product: DWC OTG Controller
                    <6>[    3.205727] usb usb1: Manufacturer: Linux 3.0.36+ host20_hcd
                    <6>[    3.205757] usb usb1: SerialNumber: usb20_host
                    <6>[    3.206036] hub 1-0:1.0: USB hub found
                    <6>[    3.206065] hub 1-0:1.0: 1 port detected
                    Donate to Finless
                      Your DMESG
                      Code:
                      Yes but not working when I plug something Usb stick or Usb audio
                        making 100% of the stock kernel's function to work also in our custom built kernel should be our 1st target;
                        then we could try fo fix broken things, then add new cool features and make some feature work much metter
                        I was just saying that I believe that broken auto brightness is due to hardware design fault.
                          Hmm, I have auto-brightness working ok on stock kernel (jelly bean), and it is quite adequate, so I keep it turned on
                            ok,
                            I did not remember auto brightness working on my own M7P back to my JB RR roms period; and on KK RR, it is not working,
                            so I did/do not miss it that much.
                              ok,
                              So you have an M7p now? Why haven't you tested the kernel builds too?
                              Feel free to compile, develop and test a fix for anything you see as not working or missing when compared to stock. I'll be checking my latest code code in a bit later but the current code is 100% for testing and working on.
                              Donate to Finless
                                Done
                                I built a kernel with Steve's DAT - so just for the record 1.23
                                Donate to Finless
