OpenELEC for s82, M8, MXIII, Tronsmart S89
    This is for the following devices:
    - Beelink S82/M8-MXIII 2GB, Tronsmart s89.
    This IS NOT for the Square m8 Box box!!!
    OpenElec Ported for EM8 1/11/2014
    - SSH U: root, P : openelec
    - Haters if you don't like then don't use
    Thanks to OpenELEC, CodeSnake, stane for their marvelous works
    Download : Flashable Zip AiO
    Unzip once on sd card or usb thumb
    updated file 02.11.2014
    Bugs are Sons of Glitches!
    JustMe
    Wohooo! A lot of people will be happy for your work.
    Is it the same as latest OpenELEC for square M8 by Codesnake?
      Nice Job, Justme! Thx for your hard work!
      I ll check your rom tomorrow... i ll see differences with Stanes AMLinux. I'm curious to see that
      Few questions to early testers...
      What about xvid videos? It's a mess with AMLinux... I think it's related to Linux AML videos drivers... but maybe...
      Is Samba server present (very pratical) ? Is Tronsmart Stock IR remote working?
        Download : OpenELEC Beta3
        I am a newbee.Thanks for the ROM/developer JustMe even though I don't know this ROM is for. How to use it and go back to android OS if I already tried this ROM ? ( Mine MX III 2 GiB is ordered and shipped to me soon.)
          Hey JustME,
          Another noob here, could you please point us to the right direction on how to install this firmware.
          also I have an MX3 with 2GB of RAM and says M82_V2.0_20140520 on the circuit board, is it compatible with this version of OpenELEC?
          Thanks.
            Originally posted by Garantita View Post
            Hey JustME,
            Thanks.
            Thank you, JustME. for your efforts.
            question:Can this be compatible for Beelink M8B round one (with red bottom ) also.
            Is there set up guidelines that we can look at for installing OpenELEC.
              i have try it on Beelink M8B round one (with red bottom )
              but no lock see first boot and them black screen
                Title is clear OpenELEC for s82, M8, MXIII, Tronsmart S89, it should install but probably due to different Wifi chipsets, -B -H variants of s802 cpu and the like, drivers for them to work or take full advantage of the hardware may not be present yet, that you can only tell when you install the firmware and test.
                The original developer that released OpenElec for Amlogic devices a.k.a @codesnake opened a thread days ago, you can find it here: http://www.freaktab.com/showthread.p...TV110-MX2-G18).
                So go ahead and START READING, you can find links to install intructions on first post, development progress and good setups info.
                As @codesnake stated he doesn't have a Round box with s802 SoC (at list not yet) so @JustMe made the port. If there are issues, missing drivers then i don't know if JustMe will be able to fix/add them but lets hope codesnake gets a s802 round box to improve our boxes even more.
                  Beelink M8B is S82. So it should be removed from topic if it's not working.
                  Problem with Beelink described above sounds the same as when putting regular Codesnake's openelec on round boxes.
                    Post one Updated with auto script flash add the 2 files to the root directory of sd + the zip from zip
                    JustMe
                      toothpick method and andriod rom
                      JustMe
                        i put the 2 files you said in with the others and at android recovery i dont see a image or whatever to flash it?
                          zip update
                          put the param and recover to sd root then put the download zip file beta3 as is and flash
                          just uploading all in one unzip once on sd and flash should be finished in 10 min
                          JustMe
                            would this work with the MXIII 1gb?
                              not sure do not own one to test on
                              JustMe
