But, you can find the current Downloads @ http://amlinux.ru/img ...
OpenELEC for s82, M8, MXIII, Tronsmart S89
installed the 17/11 release on my MX-III 2gb version and works fine. The only problem i found is related to the CEC and it's really boring.
If I turn off TV with its remote, also the box will turn off (red led). When I power on tv again the box remain off and i need to push the hardware button on that for start it.
I tried to modify the keyboard.xml mapping file and put the power button to NOOP (no operation) but it's worse: box remain on but when i turn on the tv, cec isn't responding. Seems that CEC module recognize the tv only when booted from the beginning.
Any hope to put the openelec box into a deep sleep and been able to recognize the POWER-ON command coming from the cec? Or leave it on (power consumption of this box is nearby nothing) but been able to live-recognize the cec tv?
edit:
i did another test: if when cec isn't working after leaving the box powered on, if (with the tv on) i unplug and replug the hdmi cable, openelec recognize the cec device.
So maybe a simple script well did like that can fix the problem:
When (I RECOGNIZE HDMI VIDEO OUTPUT) <----- DMESG for that
Than (DO HDMI RELOAD or better CEC MODULE RELOAD).
In that way we can leave our box on and when we poweron the tv again after a second we are able to use CEC again.
Re: OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by Condorello View Postinstalled the 17/11 release on my MX-III 2gb version and works fine. The only problem i found is related to the CEC and it's really boring.
edit:
Originally posted by leo5111 View Postwhere can i find that? thanks
It's only compatible with the 2g version so far
Originally posted by roolmapool View PostUse correct version for your device. 1711 bulid is for Beelink/Tronsmart devices (it's quoted in filename...)
No more build from dev... OpenElec is really awesome! i hope he won't stop
OpenELEC users, one question: Do you have small choppiness on 720P streaming videos (genesis)? If not what UI resolution are you using and do you have enabled option for changing display res. to video?
Originally posted by dankec View PostOpenELEC users, one question: Do you have small choppiness on 720P streaming videos (genesis)? If not what UI resolution are you using and do you have enabled option for changing display res. to video?
Like I said all I know is that, that's the only Version, I've tested from http://amlinux.ru/img that actually works on my 1G/8G MXIII. If that is really all there is to this... Then perhaps the simple answer here would be to reflect the the Device 1G or, 2G and which, unless somehow both Wi-Fi Chips are available in any given build.
DO NOT USE.. Kinda gives the impression that this could kill your Device.. In which case... IMHO they should all have that label...
Its also the same story in Stane1983's AMLinux Build too... Oddly enough. Under Android, with a working Stock (to the Box i.e. Orman's), XBMC Build. As well as the Original Stock XBMC from http://www.kodi.tv. The so-called "Spin off" XBMC. SPMC (Google Play Store), has that exact same bug in it.
Originally posted by Ichijoe View PostI asked this before, and I never really got an answer... But why is the OpenELEC-4.95.1-mx3-20141112-DONT_USE.zip actually listed as DO NOT USE?! Is it because this is the only version that works with the AP-6181 where the rest of the MX3 Files seem to be only for the older RTL8188 version?
No as I've stated above.. The OpenELEC-4.95.1-mx3-20141112-DONT_USE.zip seems to be working on my 1G/8G AP-6181 MXIII. The problem I'm having though is getting 720p/1080p Frames to render correctly. Instead of being properly centered. The seem to be rendering to the bottom right of the Screen. The upshot, of which is I get to only see the upper left quadrant of the rendered frame, and there's no real way to fix this either.
Originally posted by dankec View PostSo you think it's xbmc/kodi bug? Not related with bad amcodec?
P.s. I managed to get it to load the MTP Driver. So I'm copying that File to a MicroSD for further testing. I'll post some Pic's in-and-out of both the Stock (2160p) XBMC, the Original XBMC, and SPMC.... These will all be on the Stock 109k4 Firmware. As again I'm not going though another useless Installation of everything Android + XBMC... Just to make such a point.
I know that SBMC has displayed a similar fault, about a Week or so ago. When I last played with it. I'm kinda banking on experiencing the same Bugs, again.
If these "Bugs" are really internal XBMC related, or amcodec related.... Or in fact both? Is a bit outta my depth? I'm not really adept at writing Code.
But oh how I would love to have the Souce Code to the AMLinux Kernel & Drivers + XBMC to try and compile these myself.
*EDIT* Great its like like I almost feared it would be... Its seems like its working again...
And without a way to make a Nandroid Backup... I'm not about to touch either AMLinux, or OpenELEC any time soon... So sadly there's not much point in posting any Pics at this time...Last edited by Ichijoe; 25 November 2014, 17:01.
Originally posted by JustMe View PostThis is for the following devices:
- Beelink S82/M8-MXIII 2GB, Tronsmart s89.
This IS NOT for the Square m8 Box box!!!
OpenElec Ported for EM8 1/11/2014
- SSH U: root, P : openelec
- Haters if you don't like then don't use
Thanks to OpenELEC, CodeSnake, stane for their marvelous works
Download : Flashable Zip AiO
Unzip once on sd card or usb thumb
updated file 02.11.2014
installed that on an s82
works fine, no freezes , remote isn't working at all
New update for s82, s89, MXIII...
Clean install - http://amlinux.ru/img/OpenELEC-Amlog...arm-4.95.4.zip
Update - http://amlinux.ru/update/OpenELEC-Am...arm-4.95.4.tar
Also for MXIII, 1Gb version:
There are currently 3996 users online. 1 members and 3995 guests.
