I have one little problem, my S89H with OpenELEC, turns off when I turn off the TV. Normally that would be a nice feature, however since I am using it as PVR with recording feature, it is not a good thing for me.
My question, is there a setting to keep box alive?
Need disable CEC
via ssh
echo "echo 0 > /sys/class/amhdmitx/amhdmitx0/cec_config" > ~/.config/autostart.sh
chmod +x ~/.config/autostart.sh
After restart box CEC will be disabled.
Tvs with CEC usually have an interface to toggle these settings. I have an LG and you can access the settings by pressing the SimplLink button on the remote
Because the thermal throttling ignores the min_freq... means, if the SoC reaches a temperature where the kernel have to throttle under the min_freq the kernel will do so...
Need disable CEC
via ssh
Thanks for your help, I tried that, but it did not work..
I copied this into putty as per your instructions, is this correct?
I have an older TV that does not have CEC. I am also using a new Denon reciever, but I talked to the tech support from Denon, and he said the Device ( my S89H) is the one that has the CEC function.
You have to have the autostart.sh file in the directory before you execute the command. It will work as I had the same problem a while ago and it solved it.
I am really new at ssh, if you could get a step by step instruction, I would greatly appreciate it.
btw: this all isn't ssh (its only secure shell (a terminal), which is the same as the good old dos-prompt) BUT Linux commands...
Thanks for the help, No_Spam, razdolbaev and ccadi, now I understand the commands much better. With all your help, my box does not shut off with I change to a different source, a very big improvement. It still shuts off when I power down my system each night, but that maybe for some other reason.
My S89H running OpenELEC, is connected to my new Denon receiver, which has 6 HDMI inputs. I have a PS3, R89, Uverse cable box and this S89H connected to it via HDMI. I have one HDMI cable that feeds into my 6 year old 1080P TV. I use a Logitech universal remote to control the devices. With the remote, at bed time, I just hit one button and it shuts down the Denon receiver and the TV and the Uverse cable box.
Any ideas on why it shuts down the S89H?
thanks
Edit: further test, I powered down each device individually and my S89H did not shut down. So, that means that my universal remote is what is shutting down my box.
Problem, solved.... thanks for all your help.
Reason: Problem Solved!!!
Need disable CEC
via ssh
Thank you razdolbaev, no spam, and others, you have solved my CEC problem. Now, I have one more minor problem, when I reboot my S89H with OpenELEC 5.0 I lose my tuner connection. I have to go into"get addons", uninstall tvheadend. It will automatically reinstall it, then it will connect to my tuners. Otherwise it is working fantastic.
