OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by clarkss12 View PostSomething really strange happened, I am using OpenELEC 5.0.3 on my Vega S89H with tvheadend installed. As I was watching a live TV stream a SMS text message popped up in the lower corner of my TV screen. My granddaughter had texted me a message to my cell phone. The message was right there on the TV screen. I had been using mighty text to send and receive text messages right from my TV when I had Android installed. Is it possible that when I installed OpenELEC it did not erase the underlying Android addons, and if so how can they still function?
If you had made a backup of kodi in Android and restored it in OpenELEC all addons including mighty message were also restored.
Originally posted by razdolbaev View PostShutdown from menu (it's a not shutdown, it's suspend) i'll fix tomorrow.
<question from an hw ignorant>
Would it be possible to turn off also USB ports after a shutdown?
running some decoding test i've found some interesting results:
-decode in sw mode is basically smooth (when cpu holds), no frames dropped
-decode in hw mode is smooth, but it tends to drop frames from time to time
I noticed that either in sw or hw mode not all the cores are used (1 used in sw, 2 in hw).
Hi all,
Maybe someone already has a solution
Does anyone know what the problem is with OpenELEC 5.0.3 for M8 2GB and hardware decoding. When I playback movies with frequency 1920-1080@24Hz I get problems with my sound. M8 is connected trough HDMI to my amplifier. DTS 5.1 and DD 5,1 etc gives these problems. Sound cuts out every few seconds when I watch a movie with these soundtracks.
Problem is the same with CodeSnake M8 or Kerber S82 5.0.3 ROM. The Kerber build that I used for the M8 2GB is this one OpenELEC-Amlogic.S82.arm-5.0.3. Works well on the M8 2gb Have done every time a fresh installation of the different roms to test, but the problem persists.
In OpenELEC auto refresh frequency switching is on. I prefer movies playing at 1920-1080@24Hz.
Thank you.
Do you have enabled any A/V synchronization in settings -> Videos -> Playback?
I think I got also some problems in the past if I've enabled it. Disable it and test again. Maybe it helps.
Do you use pass-through and an external encoder? If not maybe you have to play with the settings in System -> Audio Output.
Originally posted by AndreaSpooky View Postthe *linked* shutdown using CEC is working: when i turn uff TV the box does also shut down (well, my beelink it goes from blue light to red, i guess means turn off in this case).
Originally posted by clarkss12 View PostI took a pic with my phone to show the text message, I am totally dumbfounded.
[ATTACH=CONFIG]10485[/ATTACH]
Originally posted by MikeD View PostI don't know mighty message. Is it a kodi addon or an android app?
Here is what it said. >>
"The advanced options under XBMC Remote Settings include Show incoming SMS and Show incoming calls that enable a small pop-up notification to appear on the TV when you receive a text message or phone call. This does of course require you to keep your smartphone constantly connected via WiFi to XBMC which can drain your smartphones battery somewhat, hence keep your phone on charge."
I tried to find those settings in my OpenELEC, but could not find them.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi MikeD
No, I do not use external decoders. Have had all possible settings that maybe have something to do with this problem. But the problem persists, whatever I do, or what kind of settings I use. Even if pass-through is not enabled i have problems with stereo sound that drops every few seconds during playback of movies with the frequency 1920-1080@24Hz hardware decoding.
Thank you,
Originally posted by shinysidewinder View Post@clarkss12,
Samba into your OpenELEC / UserData / addon_data folder, see if you can remove the program from there. Just throw away the folder with the name of the program. Maybe he's in there.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3084 users online. 2 members and 3082 guests.
