any idea of the changelog?
OpenELEC for s82, M8, MXIII, Tronsmart S89
I have been trying to install the new 5.0.5 version on my S89H, but it keeps going into the boot recovery screen and will not install, gives an error. I am running ver. 5.0.0 now and have gone back in forth between 5.0.0, 5.0.1 and 5.0.3 without any problems.
I even tried to revert back to Android, but same problem now, goes into recovery screen and won't install, gives an error. I used to be able to go between Android and OpenELEC, but not any more..... What has changed in the recovery image?
thanks.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI have been trying to install the new 5.0.5 version on my S89H, but it keeps going into the boot recovery screen and will not install, gives an error. I am running ver. 5.0.0 now and have gone back in forth between 5.0.0, 5.0.1 and 5.0.3 without any problems.
thanks.
I used an S82 test image 5.0.5 from the target folder from yesterday. I tried updating with update-zip but openelec didn't work properly. After flashing many other images (5.0.0-5.0.3) muliple times I finally had to make a factory reset to make openelec booting again without freezes. Sometimes images weren't flash because of fault verifying, other times same image worked.
Don't know what was the problem. Maybe new kernel in 5.0.5 image. Now I will be sure to have a full openelec backup when I start flashing a new update, especially zips. I think tar-files are save to update without problems.
Maybe using TWRP for backing up data partition is an option if openelec won't start anymore and you have no openelec backup. After factory reset and clean install of openelec you can try restoring data partition. But I don't know if it will be working.
Originally posted by MikeD View PostI used an S82 test image 5.0.5 from the target folder from yesterday. I tried updating with update-zip but openelec didn't work properly. After flashing many other images (5.0.0-5.0.3) muliple times I finally had to make a factory reset to make openelec booting again without freezes. Sometimes images weren't flash because of fault verifying, other times same image worked.
Maybe using TWRP for backing up data partition is an option if openelec won't start anymore and you have no openelec backup. After factory reset and clean install of openelec you can try restoring data partition. But I don't know if it will be working.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
No, I tried only to install 5.0.5 but it didn't work. But I didn't use the actual build from /image/5.0.5 folder. I'm on 5.0.3 again.
My box never boot directly to recovery without using the toothpick. I just had bootloop on openelec logo. That was my problem. Maybe your reset button is damaged and it's constantly pressed now?
I also have no write access to sdcard. But I didn't try it before. Don't know if it's working in older releases.
Originally posted by MikeD View PostNo, I tried only to install 5.0.5 but it didn't work. But I didn't use the actual build from /image/5.0.5 folder. I'm on 5.0.3 again.
I also have no write access to sdcard. But I didn't try it before. Don't know if it's working in older releases.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I could even put the 3 Android files on my micro SD card and using the tooth pick method, the little green man always popped up. I have probably done this a dozen times, going between Android and OpenELEC and never had a problem.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Do you have a recovery.img file in the root of your sdcard?
When you hold reset button on booting first destination for loading recovery.img is root of sdcard. If there isn't one the box boots the recovery from internal flash. If this recovery is corrupt and you don't have one on sdcard your box can't boot to recovery.
Originally posted by MikeD View PostDo you have a recovery.img file in the root of your sdcard?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2637 users online. 1 members and 2636 guests.
