But I think my posts could help others struggling with remote configs and help to understand how it works.
OpenELEC for s82, M8, MXIII, Tronsmart S89
If you don't want to use original remote than I don't need to help you get it working.
Originally posted by wpb View Post
I'm sure your most recent post where you went through your debug ideas, can be very helpful, no doubt.
I did test without the MCE receiver plugged-in. I haven't tested that again in some time .. I think the last time I tested it I was running 4.97. I'll test again and post here if better results in 5.0.5.
Originally posted by EGM92 View PostIs it possible to restore and go back to android after installing this?
First thing you need to know is which specific box/chipset (and partition structure) you have, to determine which ROM you'll use.
Originally posted by wpb View Post@EGM92 - Yes, you have a few options. Boot to the custom recovery and backup your current system before installing (highly recommended), or just make sure you have a compatible ROM prior to flashing this. If you do, you can restore back to your compatible ROM with settings overwritten.
Originally posted by EGM92 View PostI know what box I have MXIII 2GB. I've tried getting into recovery via the toothpick method with no avail. I put the firmware files on my microSD, pressed and held the recovery button, pressed the power then it just keeps restarting to the Amlogic screen.
Read this link and maybe it may work for you.
http://www.freaktab.com/showthread.p...mlogic-devices
First, I convert the stock recovery S82B to tar file and put in openElec sharing update folder-Reboot-Reboot. The I use your instruction for OpenELEC hard reset. Bingo, I flash back to Finless 2.1
Stock recovery in flashable zip:
- Beelink S82b (108k4)
- Beelink S82b (109k4)
- Tomato M8 updated
- Minix X8-h beta9 r2
Edit, these roms are for those boxes, you will need the rom for your box.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostDoduong had similar problems getting back to Android from OpenELEC, here is his solution.
- Tomato M8 updated
I have the correct ROM for my box. I've extracted it, found the recovery file. I samba'd into my box. I can access any of the folders required, I'm guessing the update folder is the \\IP\Update folder in samba. I'm not sure what Openelec hard reset is.
If you want to go back to Android just flash your zip in recovery with "update from EXT" like you have done with openelec. After flashing Android rom you have to make factory reset in recovery before you reboot the box.
If you don't want to lose your kodi database you have to use addon "xbmc backup". Backup all your files to SD card or transfer it via ftp to your pc. In Android you can restore it again with this addon.
Originally posted by MikeD View PostIf you want to go back to Android just flash your zip in recovery with "update from EXT" like you have done with openelec. After flashing Android rom you have to make factory reset in recovery before you reboot the box.
@MikeD -
Back to our conversation about remotes. Strictly for academic purposes, I ordered two M8's / S82's during our conversation. They arrived today.
Strange thing is, they now appear to be shipping with a different remote (notice the clear power-button on the right with TV-remote (not M8 box) features associated with it):
Ignore the box itself, that is not the box I purchased, simply the only box I could find on Google Images that contains the new remote I wanted to show you.
Here's where it gets interesting..
You know how you said I was completely wrong, how all the remotes are the same, I'm the only one with the issue, etc?
The original S89 remotes (as we've discussed in the past), on all 4 of the S89 boxes, register NOTHING when I'm debugging in the OpenElec ROM. No IR commands whatsoever, including testing without the MCE receiver. Nothing has changed with that original issue.
Here's where it gets interesting...
Those same, original, S89 remotes *do indeed* register IR codes when I use them on the OpenElec ROM installed on the new S82 boxes.
However .. The *new* remotes, which worked great in recovery and the original Android ROM, *do not* work in the OpenElec ROM. In addition, there is no input recognized whatsoever in debug mode in OE.
In summary, I spent $170 to prove what I already knew -- but you caused me to wonder if maybe I was just crazy and somehow was unlucky enough to receive 4 flawed boxes.
The S89 box (without MCE receiver plugged-in) did not work with the original remotes that look identical to all other S89 boxes, not in OE. Yet that S89 remote does work fine with that remote when running the original Android ROM (Mediabox).
The new S82 boxes work with the S89 remote, but not this strange new remote shown above, yet that new remote does indeed work with the original Android ROM (Mediabox).
There is evidently some minor difference in either the IR receiver or some strange timing/compatibility issue. I don't proclaim to know the answer, but it's not as simple as "all S82/S89 remotes work".
To be clear .. I'm not talking about remotes that look different, of course those have differences -- but in remotes that look identical there can be differences, evidently. I've now tested on 6 boxes with very consistent results. Not everyone has the problem, sure. Maybe it has to do with different manufacturing runs, I don't know.
What I do know, is that I've spent a lot of time and money to prove this and it would be great if you'd agree: there may be an issue with remote compatibility beyond the scope of your knowledge, and that the S82 OE builds do not necessarily work with all S89 boxes despite the remotes looking identical.
With this experiment behind and moving on...
The problem is that I have no idea what to do considering no IR codes are being received by OpenElec. I know the remote is working great, I just go back into recovery and it works fine, so it's OE specifically.
But if there are no codes being received in debug mode, what is the next step to enable this remote in OpenElec?
I would install the original Android rom and transfer the /etc/remote.conf to your PC. Then install openelec again and do the same. Those two files should be different if your remote doesn't work in OE but in Android. If they are different you could place the one from Android in /storage/.conf in OE and reboot. Maybe the remote works then.
If they are identical I really don't know why they don't work.
And I want to make clear that I've never said that all S82/S89 remotes have to work. I've just said that until now you're the only one who got problems with that.
Because you've said that the S82 releases from amlinux.ru don't work with original remotes I just wanted to say that this is not the common case.
If the manufacturers are shipping now different kinds of RCs it's clear that those new ones don't work in OE. Those images are build for one RC with a specific factory ir code. Maybe there are also some same looking RCs with different factory codes. I really can't know that. I have just one box.
And I have to say that I only know this from my experiences with editing the remote.conf to use OE with another RC. I'm not an expert on this and could be wrong about some points.
I'm a bit of a noob when it comes to linux. I know how to ssh into devices but when it comes to commands I don't know left from right.
I have an MXIII 2GB installed with a Openelec 5.0.5 it's working pretty solid. I'm trying to get some NHL streams to work, but I need to get java installed as editing the hosts files. Does anyone have a through tutorial or can give me a hand? I'd really appreciate the help.
Originally posted by MikeD View PostOn www.amlinux.ru/image you can find different images for S82 (S89) round devices. Working without problem here (OE 5.0.3).
Secondly what is diff between these 2 anyway? I am wondering if it worth the efforts, as I don’t want to make mess of my box, I spend hrs setting up in the first place.
Thirdly
I have two of these box one elite and with H, I can safely use both remotes interchangeable with any issues, only thin I have noted is my TV samsung >CEC<openelec, I could power off the box with Samsung remote but couldn't power up the box, so I have to use the S89 remote. For me it is not an issue, but it would be nice having a single remote (Samsung) to do all the navigating any solution for this?
Appreciate your supports
1) I have updated to latest version 5.0.5 (06 March) without problems. Should be safe but best is to have an openelec backup in worst case.
2) Most differences are in update of kodi to 14.2 (I think). But it's hard to say exactly because there could be made changes in kodi, openelec and some hardware related by image developer.
3) CEC power on is currently not supported by Amlogic and propobly will never be. So easiest solution would be a universal RC if you want only one remote for TV and media box.Last edited by MikeD; 12 March 2015, 23:49.
Originally posted by MikeD View Post1) I have updated to latest version 5.0.5 (06 March) without problems. Should be safe but best is to have an openelec backup in worst case.
2) Most differences are in update to kodi to 14.2 (I think). But it's hard to say exactly because there could be made changes in kodi, openelec and some hardware related by image developer.
3) CEC power on is currently not supported by Amlogic and propobly will never be. So easiest solution would be a universal RC.
There are currently 2545 users online. 0 members and 2545 guests.
