It took me a while but i managed to install s82 5.0.6. And its running fine now =).
First i just updated to 5.0.6, after that i thought to factory reset my box.
After this reset ended up with a black screen after the Tronsmart logo (it was pretty sure a frezz).
I tried to go back to the MX3 5.0.6 version. I also ended up with a blackscreen after the Tronsmart logo.
(Remember everything worked before i factory reseted my box)
So i went back to Android. Ok Android worked, so i gave it another try to install MX3 5.0.6. Still no success.
Than i tried to install the M8 5.0.3 version. Success! Remote and Wifi doesnt work, but it booted to the Kodi menu.
I factory reseted my box again and booted again, openelec still worked. After that i tried MX3 5.0.6 again, and it worked again!
I factory reseted again and endet up with a black screen again.
Here i tried the MX3 5.03, S82 5.0.5, S82 5.0.3. Nothing worked.
So i flashed M8 5.0.3 again. It was working. Without factory reseting or something like that i flashed S82 5.0.6. And yeah. Now everything works fine.
I dont know why but i guess openelec have to be started at least one before i can update to the S82 verison.
I flashed a lot today xD. I think i will only flash my box again when theres a linux where i can start emulators out of kodi
Everything works now without problems, thanks all =)
