The Analogue Audio however is not working with 5.0.8 (as it is not with 5.95 either as previously reported) and I have tried all options plus passthrough etc and still nothing. I am wondering though if the incorrect driver is in the build as it says "AML-M8AUDIO Analog" and perhaps the MX3 analog audio driver is different from that which is there (M8 ?). I hope this feedback can lead to a fix. Many thanks.
OpenELEC for s82, M8, MXIII, Tronsmart S89
I flashed mine back to 5.0.8 and "Power Off System" works from the power menu ! Also with 5.0.8 while playing a video you can drag (with a mouse, holding down left button) the slider to seek backwards and forwards within the video but with the 5.95 versions, this function is broken, you can only click to where you want to go. So for me, 5.0.8 is currently the best MXiii option. I wonder if the difference is that the 5.0.8 has the Google TV bootscreen and the 5.95.x has Tronsmart boot screen so perhaps the bootloaders are different ? Just a thought.
Flashed the new 5.95.3 version but have a problem: It won't remember the static IP settings. Every reboot it gets another IP while in the OpenELEC settings I have switched to manual IP .
Tried a complete new flash after trying an update via SSH. Still the same problem
Anyone, any suggestion on how to fix this?
Im no good at all at Linux commands. Just to make sure:
First I SSH into the box
Then I type the code below that makes me create the file autostart.sh
Code:nano /storage/.config/autostart.sh
Code:ifconfig eth0 up ifconfig eth0 192.168.2.85 route add default gw 192.168.2.1
Then I save the file and reboot right?
puhhh i really lost track in this Thread...
I have ordered an "Tronsmart MXIII Android 4.4.2 TV Box Amlogic S802 Quad Core 1G/8G" and i am really not sure which version is the newest and confirmed working. It would be really helpful if somebody could drop a Link with the files for NAND. With the links posted i cannot find MXIII in the filename.
On this index-site you find the different OpenELEC-versions. In version-folder you find files like OpenELEC-Amlogic.arm-S82-x.xx.x.x.zip. This "arm-S82" means TV-Box with Amlogic S802 SoC, which your ordered Box has. So you must download an file called "...arm-S82....".
For now Kerber (the dev) works on OE5.95.4, which includes Kodi15.1rc. But atm is not for Amlogic S82. You should wait few days, and then install the newest version.
There are currently 1435 users online. 0 members and 1435 guests.
