OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by jae View PostWanted to try this on my Tronsmart S89 Standard. Link in the OP seems dead.
Anyone have a mirror?
You have to download from amlinux.ru/image now
Has anyone had any luck with the latest Openelec builds? The last one I could successfully flash was 5.0.6. 5.0.8 appears to flash successfully, a google tv logo displays and then the screen goes black forever. The latest, 5.95.2, also appears to flash successfully. It boots and then shows the Openelec logo, but then it drops me down to a console with the message "sh: can't access tty; job control turned off" in the upper left corner. Ive tried flashing/redownloading both many many times. Ive tried different versions of recovery including the one that comes with finless 2.1. Ive tried installing with the tar file. No luck. Very frustrating. argghh
BTW, I have a Tronsmart s89Last edited by derzahla; 07 July 2015, 00:34.
Hmm. Do you mean the WeTEK edition? I tried flashing RemiX115k4 first and then openELEC 5.95.2 wetek. Thisactually bricked my device. Had to use my wifes chinese windows laptop to flash it back to stock over USB. Then tried flashing http://amlinux.ru/image/5.95.2/OpenE...5.2-update.zip, same error at boot. Now im back on 5.0.6. This is crazy.
Originally posted by derzahla View PostHmm. Do you mean the WeTEK edition? I tried flashing RemiX115k4 first and then openELEC 5.95.2 wetek. Thisactually bricked my device. Had to use my wifes chinese windows laptop to flash it back to stock over USB. Then tried flashing http://amlinux.ru/image/5.95.2/OpenE...5.2-update.zip, same error at boot. Now im back on 5.0.6. This is crazy.
You have to use S82 version with your Tronsmart Vega S89! No problem here with 5.95.2 image.
I've tried the s82 version as well (first actually), as that's what I previously used for earlier versions. But now with 5.95.2, there is an s802 labeled version, which is the exact cpu that's in the tronsmart s89. Im pretty sure there is no amlogic s82 CPU, though I have heard some sites calling the Amlogic s802 an s82. Never understood why.
MikeD, what version were you on before you flashed 5.95.2? Which method did you guys use to flash and which recovery img?
Thanks.
The names in all those versions stand for the box type, not the processor. S82 means Beelink S82 which is same as Tronsmart Vega S89. S802 is for CX-S806 box.
The version don't have to be only compatible to your processor also wifi chip, remote and maybe other hardware. So you have to choose right version for a model which have exact hardware than your box.
I have a S82/S89 clone and use the S82 versions from beginning without problems.
There are currently 2029 users online. 0 members and 2029 guests.
