Edit, Sorry i thought you were asking me
OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by MikeD View PostNo, I just installed the S82 version from recovery without wiping anything.
In his method he made a factory reset so you will lose all your settings if you do that.
BTW: He just installs mx3 version before s82. These two files (recovery.img and factory_update_param.aml) are optional and don't have to be used. If you have recovery.img in root of sdcard your box will boot into this recovery instead of recovery on flash which will be installed with every rom (open a image zip and you see recovery.img).
The other file is just for automatic flashing. If you open this file with text editor you see that it defines which zip image should be flashed on start of recovery. If this zip isn't found it doesn't do anything.
Be sure to use latest recovery (extract from latest openelec) to install zip. Maybe you have an old version in root of sd and that could cause problems too.
But there's still "black screen" bug which appears occasionally and only when system resolution in 1080p
What do mean with "black screen" bug? On boot or on starting a video?
I got black screen (more exactly losing video output, sound is still playing) if I want to start a 3D movie and want use 3D GUI. If I set in Kodi to ignore 3D mode I have no problem.
I could also set 3D mode (SBS or TAB) before starting the movie. Then it works with 3D GUI.
That is for me currently the most annoying bug.
Originally posted by MikeD View PostWhat do mean with "black screen" bug? On boot or on starting a video?
When I start a video. Video is playing, but I have no picture...
I'm not interested in 3D so "ignoring 3D mode" will be a solution for me, if then everything else is fine...
How did you force kodi to ignore 3D?
I have no problem with non 3D movies. They play just fine.
I got only blackscreen if Kodi wants to set GUI side-by-side or top-and-bottom to match 3D video file.
Anywhere in settings (don't know exactly right now) you can set "Ignore" 3D mode. But that only has an effect if you start a 3D video. For 2D it doesn't matter.
Maybe this is a common problem if Kodi wants to change video screen settings on movie beginning. Try to set same screen settings (resol. and fps) like video and test again.
Originally posted by MikeD View PostI have no problem with non 3D movies. They play just fine.
disable suspend/shutdown completely
Just installed 5.0.6 (S82), works fine so far. But when I switch off my TV, the box switches off too. That was no problem with 4.97 but since 5.0.3 it does not come out of suspend right. My MCE USB with Harmony is not working anymore, I have to restart with the sh*tty Original remote. That was something I could (and even more my wife :-) ) handle. But with 5.0.5 it totally freezes after reboot, I have to reset the power. Same thing with 5.0.6 :-(
Now I just want to prevent any automatic shutdown/suspend/whatever. The WAF is more important than a few cents for the power.
How do I do that? I searched the openelec forums etc. but no luck.
Thanks in advance!
Originally posted by mboka View PostJust installed 5.0.6 (S82), works fine so far. But when I switch off my TV, the box switches off too. That was no problem with 4.97 but since 5.0.3 it does not come out of suspend right. My MCE USB with Harmony is not working anymore, I have to restart with the sh*tty Original remote. That was something I could (and even more my wife :-) ) handle. But with 5.0.5 it totally freezes after reboot, I have to reset the power. Same thing with 5.0.6 :-(
Thanks in advance!
Originally posted by ccadi View Post
A bug in 5.0.6 with s82b:
After watching ".ts" videos, more precisely, when you stop them, a "black screen" appears (you don't see anything but kodi is working in background).
I ended with power off device by heart: power key, down key, OK key and turn it on again. Then everything's work again.
There are currently 3444 users online. 0 members and 3444 guests.
