Why you want to shutdown kodi with remote? Is the power consumption higher than in other releases in standby?
OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by MikeD View PostWhy you want to shutdown kodi with remote? Is the power consumption higher than in other releases in standby?
Originally posted by MikeD View PostI'm not 100% sure but I think it's more a sleep mode with saving ram in nand. So you can power on device and start were you left. When the box is in standby there is no ssh and http server running. Also I can't control or power on the device with yatse so I think there is no kodi service running.
Originally posted by drieschel View PostSleep mode with saving ram IS suspend mode. I want to shutdown the OS and not suspending it. There is nothing to discuss about! Thanks for your replies @MikeD, even if they were not very helpful.
Years ago, with the 10 meg hard drives it was common practice to shut down the computer every time you left it for more that 30 minutes, what a pain. Now, it seems to be the thought that it is better for the hard drives to remain running, rather than shutting them down. Todays hard drives are meant to be running all the time.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI think what you are referring to is an age old controversy about shutting down the computer each night or leaving it run all the time. If I read you correctly, you are concerned about your powered external hard drive being powered even when you are in suspend mode. I think that is a valid concern, but with todays hard drives, it is not a big factor.
Years ago, with the 10 meg hard drives it was common practice to shut down the computer every time you left it for more that 30 minutes, what a pain. Now, it seems to be the thought that it is better for the hard drives to remain running, rather than shutting them down. Todays hard drives are meant to be running all the time.My NAS is running 24/7 (with suspending harddrives in idle indeed) but that's not the reason why I am writing here. I simply want to shutdown the "OpenELEC" OS, when I turn off (going into standby mode) the S82.
I am sure razdolbaev (|Kerber|Surkovalex) understands what I am talking about.
Originally posted by drieschel View PostI am not sure where you read about my concerns about an external harddrive.My NAS is running 24/7 (with suspending harddrives in idle indeed) but that's not the reason why I am writing here. I simply want to shutdown the "OpenELEC" OS, when I turn off (going into standby mode) the S82.
I am sure razdolbaev (|Kerber|Surkovalex) understands what I am talking about.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by razdolbaev View Post@drieschel
Yes, I understand what you are saying. One of these days I'll try to make this function.
Let me know If I can support you. I forked your OpenELEC.tv fork on github already, I have some experience in script languages (like bash) and OOP (but not very much experience with C++). If you could introduce me to this project would be great.
Yes, I understand what you are saying. One of these days I'll try to make this function.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by AndreaSpooky View PostI would like that too, since in suspension mode the external ports are always on, hence hard disks go never in complete shutdown, and they actually go warm even if not rolling.
Originally posted by drieschel View PostSleep mode with saving ram IS suspend mode. I want to shutdown the OS and not suspending it. There is nothing to discuss about! Thanks for your replies @MikeD, even if they were not very helpful.Last edited by MikeD; 02 March 2015, 20:01.
Great, on latest http://amlinux.ru/image/5.0.3/OpenEL....arm-5.0.3.tar HEVC H265 stuff goes a lot better (multithreaded) and now is possible to see stuff without stuttering if bandwidth required is <1MBps
There are currently 2532 users online. 0 members and 2532 guests.
