flashing back to custom m8 4.9.7.3 at least that recognizes the box properly
OpenELEC for s82, M8, MXIII, Tronsmart S89
keeping my one box on 5.0 and the other on 4.9.7.3
Originally posted by xoexpireu View Postflashing back to custom m8 4.9.7.3 at least that recognizes the box properly
started from scratch on my other box fresh install 4.9.7.3 going to start testing in a minute
5.0 stiil reboots reflashed 4973 still going strong
Originally posted by xoexpireu View Postkeeping my one box on 5.0 and the other on 4.9.7.3 been running another movie on 5.0 for an hour now no reboots yet ill keep testing but no wifi on it has to be hardwired.
5.0 stiil reboots reflashed 4973 still going strong I just read in some earlier posts people flashed s89 on the mx III 4k 2g and its running I think im going to try that tomorrow and see what happens. thinking mx3 was built for 1g version with different wifi chip. almost ready to throw in towel on these cheap boxes and get a zotac zbox or a gigabyte brix i dont want to spend hours and hours on this with no progress.
Originally posted by xoexpireu View Post5.0 stiil reboots reflashed 4973 still going strong I just read in some earlier posts people flashed s89 on the mx III 4k 2g and its running I think im going to try that tomorrow and see what happens. thinking mx3 was built for 1g version with different wifi chip. almost ready to throw in towel on these cheap boxes and get a zotac zbox or a gigabyte brix i dont want to spend hours and hours on this with no progress.
HDHomerun
Firstly, great work from all involved. I've got 5.0 installed and everything is working beautifully - except I can't get my HDHomerun connected no matter what I try.
I've seen a few posters who have managed to get one working, can you post exactly what you did?
I have the HDHomerun drivers installed and have copied the sample conf file but my tuner just refuses to show up.
if u go back to page 9 on this thread post from slappy says use s82 5.0 for mxiiii
Originally posted by gendo View Posts89 is for 2g box whilst mxiii is for 1g box
Originally posted by d3ft View PostFirstly, great work from all involved. I've got 5.0 installed and everything is working beautifully - except I can't get my HDHomerun connected no matter what I try.
I have the HDHomerun drivers installed and have copied the sample conf file but my tuner just refuses to show up.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by xoexpireu View Postim using my phone to browse these pages but on page 9 theres a post from slappy saying to use s82 5.0 on the mxiii 2g version can anyone confirm this i will try tonight when i get home?
I am using the S82 version on my MX3 2G and think it's very good, the wifi and the ram are used in this version. the only problems I have come across so far is if you shut down from the menu it will reboot. and if you suspend from the menu it will appear to suspend but is not able to awaken, you have to cycle the power to regain the box.
Am I able to edit keymap to address these problems. If suspend is a problem can I just remove the option from the GUI.
PS using: OpenELEC-Amlogic.S82.arm-devel-20150130094357-r20557-g8fc79be-update.zip
CPU temperature is much lower in this build I think.
Originally posted by clarkss12 View PostWhat config file? You did install tvheadend? You did access the configuration page using your web browser, by typing in your IP address with :9981? If tvheadend configuration page on your computer web browser does not show your tuners, go into the system settings on Kodi running on your OpenELEC box, and disable tvheadend and wait a couple of seconds and then enable it. The configuration page on your web browser should show the HDHomeRun tuners.
The network connections info in OpenELEC settings shows I've made an ethernet connection to my HDHomerun but I can't see any evidence of OpenELEC seeing the tuner. I've tried all manner of disabling and re-enabling each add-on and still no joy.
Does the driver work for all HDHomerun versions or only the newer ones? I have the old DVB-T dual tuner.
Originally posted by d3ft View PostI've installed the HDHomerun drivers, the TVheadend backend as well as the TVheadened PVR add-on. I can access the web interface at localhost:9981 but my tuners don't show up in the tuner tab. The config file is the one referenced at the OpenELEC wiki for the HDHomerun driver. It tells you to copy info from the sample file and replace the default device ID with the one written on the bottom on the tuner box.
I did not have to add an additional HDHomeRun config file.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostMy oldest HDHomeRun tuner is an HDHR3. And no problems at all. In your configuration page did you setup a network?
I tried with an without the config file so I don't think that is the problem.
You just plugged yours in and it worked straight away? No setup in OpenELEC required?
Originally posted by d3ft View PostI'm accessing the TVheadened interface from another PC on the network so there's no issues there.
You just plugged yours in and it worked straight away? No setup in OpenELEC required?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostYes it detected both my tuners right away. I don't recall, if I had to open any ports on my router. Check your router ports, and also make sure your firewall is not blocking it. I do have ports 9981 and 9982 opened on my router that I opened, but can't remember why I opened them.
There are currently 2376 users online. 0 members and 2376 guests.
