OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by xoexpireu View Postas of yesterday i still get random reboots i hant changed any xml files but i will take a look at it. is there something specific to look for?
Did you have any problems with rebooting while using Android?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
no no problem at all using android other than being really slow and laggy
Originally posted by clarkss12 View PostI am using a Tronsmart Vega S89H, and I have never had a reboot issue with this box, running Android or OpenELEC. I am not sure that OpenELEC is causing your reboot. One my other Android boxes that had constant reboots, it was usually a driver or something in the firmware.
mine works great 1080p 1080i except random reboots i cant figure out why
Originally posted by Condorello View Post+1, very shuttering and delayed. Impossible to watch, but the dame video (1080p) works fine if i set 720p@60
Originally posted by xoexpireu View Postmine works great 720p 1080p 1080i picture video quality everything works great except i keep getting random reboots mostly approx 1/2 hour to 45minutes it just reboots for no reason right at all the good part of the damb movies lol sometimes if I try to skip back to the chapter too fast of the movie it will justvreboot as well i think this is a kodi issue not elec but im not 100% it could just be my MK III m8 2/8 is not powerfull enough anyone have any ideas about this problem anything i can check????? I may have to wait untill the weekend to really dig into this again but anyones suggestions or solutions is greatly appretiated Thankz
I really don't have any ideas unless it is your power supply. If you have another one to try, that would be the first step.
I am using the latest 5.0 version from this link.
And this one specifically.
OpenELEC-Amlogic.S82.arm-5.0.0.zip
I think this is the one you should be using.
OpenELEC-Amlogic.MX3.arm-5.0.0.zipMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
im going to try fresh install tonight with version 15 im on 14 now so maybe thats it
Originally posted by MikeD View PostMaybe there are differences in the versions of MXIII and S82. I also have no problems with 5.0 on S82.
And you should make a fresh install and test some videos without installing any addon if you haven't done yet.Last edited by xoexpireu; 03 February 2015, 19:10.
Almost perfect with S89 and 5.0....
Release 5.1 in pipe(i see empty folder at the moment)
Originally posted by xoexpireu View Posteverything so far so good but i dont jave amy Wifi???? i need that for my second box in bdrm im thinking the openelec mx3 i downloaded above is no good for my mx III ?????MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
it only rebooted once but i was playing a movie and scrolling through settings really fast
Originally posted by clarkss12 View PostHas the rebooting problem been solved with that OpenELEC?
Spoke too soon it just crashed in the middle of a movie damb?????
There are currently 4887 users online. 0 members and 4887 guests.
